speaker sidewall
ryu4000
ryu4000 Posts: 9
edited August 2013 in Troubleshooting
Does it matter if one speaker is 2inches more from the wall then the other speaker? would it make a different?Cause right now i got one speaker a little farther from the side wall then the other.Would this mess with imaging etc...?
Post edited by ryu4000 on
  • boston1450
    boston1450 Posts: 7,758
    edited July 2013
    Have you tried moving them around some ? Did you notice a difference ? If not-dont be too worried about it. It may effect alittle bit if your good with it-thats all that matters. Sometimes speaker placement can be difficult. So we need to improvise. Depends on the speaker too :) play around with them & enjoy
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • HK_VIP
    HK_VIP Posts: 11
    edited August 2013
    Most receivers these days will have a microphone that can be used to calibrate your speakers. This means that the volume on the speakers will be automatically adjusted for you. It will calculate the distance between the speaker and the listening area and adjust the volume accordingly.
    However, if your receiver does not have this feature you may manually calibrate your speaker settings by adjusting the volume until their is a balance between the right and left speakers.
    Polk R300 x2
    Polk R150 x2
    Polk CSR
    Polk OWM3 x2
    Polk PSW10
    Onkyo HT-RC460
    VideoSecu MS07B M99 x2 (Adjustable stands for the R150's)
