Proper burn-in of new crossover components?
gmjungbluth
Hello all,
I'm at the 75% point on the restoration of my Polk Monitor 7Bs. When they're back together I'll post a full story of my work.
Here's a short rundown of what's on so far:
1. rebuilt crossovers with Dayton 1% caps, Mills resistors. left the inductors alone.
2. Replaced old posts with new gold-plated 5-way binding posts from PE
3. Added acoustic foam to back and side walls of inside cab.
4. Affixed acoustic deadening materials to MWs and PRs
5. JB Weld woofers
6. Larry's Rings for PRs, MW, and Peerless Tweeter
7. Pulled old Vinyl off, put on new real cherry veneer. Stained veneer
I have to seal the veneer (going to do a satin poly wipe-on) and reassemble. At some point I'd also like to put new grille cloth on the grilles. I have two pairs of grilles so I was thinking of going a little out of the ordinary with one pair and try white or brown cloth. we'll see.
My question is how should I burn in the crossovers? I've read that the caps need some time to come into their own. On other recaps I've done I have immediately noticed a positive difference in the sound of the speakers but to be honest I have so many pairs and so little time to listen that I doubt I've burned in any fully yet.
I got my Pioneer SX-1250 back after a recap and it had been burned in for 4 days, and sounds great.
For speakers, what should I be doing to get these burned in? Can I just leave the radio on playing through them for a few days?
Thanks!
G
5. JB Weld woofers
Thanks!
G
HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100
Post edited by gmjungbluth on
Just use the speakers as normal. Everyone here has all their cables, amps, pre's, crossovers burnt in by simple virtue of use. Sounds like you had a fun project
gmjungbluth wrote: »For speakers, what should I be doing to get these burned in? Can I just leave the radio on playing through them for a few days?
Yep, that'll work. Could take anywhere from 50-200 hours for them to fully burn in."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Don't fret it, just enjoy your tunes.If you can't hear a difference, don't waste your money.
You can use pink noise which is a headphone'r favorite, but just using them works fine as long as you acknowledge that what you're hearing from minute one will change.
Thanks all. Does it matter what volume they're set at?HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
Just listen to them as you normally would. Around 200 hrs seems to be the point where no further changes occur across all brands.Home Theater/2 Channel:
dhsspeakerservice.com/
