Height for rear speakers
Middlebush
Middlebush Posts: 13
How high from the floor should rear speakers be? I have Polk SDA 2's for the front and Polk RM8's for the rear.
  • B Run
    B Run Posts: 1,888
    edited July 2013
    I like mine about a foot or two above ear level, kind of a personal preference. You can do anything from ear level to in-ceiling so it's up to you.
  • Middlebush
    edited July 2013
    Thanks :smile:
  • HK_VIP
    HK_VIP Posts: 11
    edited August 2013
    Most recommend that your speakers are all at ear level or just above ear level. This includes the center, front speakers, side speakers, and even rear speakers.
    Rear speakers can be placed behind you on stands, mounted on a wall behind you, or on the ceiling above or behind you. It would all depend on the size of your room and if you are able to place speakers behind you or not. If you are limited on room size then I would recommend that you mount your speakers above and behind you. Depending on your mounting options you may be able to place them in a position where they are firing sound directly at the listening area. They should be mounted at your ear level or above ear level. Don't place the rear speakers to close to each other. Widen them out for best results. Most receivers these days will have a microphone that can be used to calibrate your speakers. This means that the volume on the speakers will be automatically adjusted even if you place them too high above ear level or it will lower the volume if they are placed at ear level.
    Polk R300 x2
    Polk R150 x2
    Polk CSR
    Polk OWM3 x2
    Polk PSW10
    Onkyo HT-RC460
    VideoSecu MS07B M99 x2 (Adjustable stands for the R150's)
  • Syndil
    Syndil Posts: 1,582
    edited August 2013
    Dolby Labs suggests surround speakers be mounted just above ear level.
    http://www.dolby.com/us/en/consumer/setup/connection-guide/home-theater-speaker-guide/index.html
