My new 2 me adcom
boston1450
boston1450 Posts: 7,758
edited August 2013 in 2 Channel Audio
Took the morning off to go check on a Adcom on Clist. I was smiling ear 2 ear when i left with it. Has one little scratch on it. But i am very happy. A special thanks to those on here that helped me with questions regarding my SDA's & how they match with Adcom. So i took the plundgeAttachment not found.GFA-555 & GFP-565 hope to have it hooked up this weekend. But its back to work for now. Thanks again everyone :)
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
Post edited by boston1450 on
  • boston1450
    edited August 2013
    Backside
    Randy-Maine
    by David WMG
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited August 2013
    Congrats. You should be pretty happy with it. Interested in your impressions on the phono input on that pre and how it compares to anything else you've used. Enjoy.
  • monepolk
    monepolk Posts: 1,154
    edited August 2013
    Congrats on the new amp.
    edited August 2013
    Careful that that Adcom doesn't blow you into your neighbor's house! But most of all, have fun!
    cnh
  • GFOviedo
    GFOviedo Posts: 353
    edited August 2013
    Congrats!
    AVR: DENON X4000
    FRONT L/R: ARX A3RX-C
    CENTER: ARX A2RX-C
    SURROUND L/R: ARX A3
    SUBWOOFER: PSA-XV15
    SERVER: UNRAID 15TB
    MEDIA PLAYERS: DUNE SMART SERIES D1
    HDTV: VIZIO M601D-A3R
  • DaveHo
    DaveHo Posts: 3,583
    edited August 2013
    Congrats. The back of the GFA-555 looks a little odd. Am I seeing things or are there other connections below the factory installed binding posts?
  • DaveHo
    DaveHo Posts: 3,583
    edited August 2013
    In addition, now you can try out the Carver you picked up the other day!
  • boston1450
    edited August 2013
    TNHNDYMAN wrote: »
    im going to be using the Yamaha cr2040 for phono. Or my Marantz w/6300 for Albums
    i want a SACD or something different for this Adcom set up....time to say goodbye to my trusty old HK cd player ive had for YEARS.time to catch up with times.....thanks all. I hope to get it up n running asap. I need to rearrange wtuff so its not that easy-but fun......i have lots of questions 1) is it ok to keep Pre-amp on top ?--or will heat be problem ?
    2) i may want tuner. But is there a way i can use the Carver temp ? Or would i have to use that by itself because its a pre-am/tuner..... (Id like to pick up a Adcom tuner,but wallet says NO) i will be hooking up amp & pre-so if i cant ad the Carver as just a tuner. It wont happen. I will wait it out till i buy one or use a crappy ars sony i see for 10.00) any thoughts before this weekend is great.......thank you kindly again--randy
    Randy-Maine
    by David WMG
  • boston1450
    edited August 2013
    DaveHo wrote: »
    i never did hook that up yet. Lol. Now i can easily check it over. Good thinking :)
    Randy-Maine
    by David WMG
  • stretchl
    stretchl Posts: 1,334
    edited August 2013
    Very interested in how you hear the highs with this. It's the one criticism I've read. I have the 555-ii and I think it gets a little harsh on the top end. But I have tinnitus and that may be the culprit.
    Enjoy!
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited August 2013
    Congats on your new toys.I think your going to like the clarity of the Adcom.But what do know .All I know it's very powerful and comes on instantly and just pumps. Mine unless pushed using multiple speakers barely gets warm,I'd like to know if I just have a great piece or Adcoms are known for that.
  • DaveHo
    DaveHo Posts: 3,583
    edited August 2013
    You should be able to use the Carver as a tuner. Simply put the Carver into tuner mode & connect a tape out from the Carver to any input other than phono on the Adcom. My 555 generally runs pretty cool unless I'm using lower impedance speakers at higher volumes. Though most of the heat is given off by the heat sinks in the rear. I personally don't like stacking anything on top of an amp, but realistically if whatever you put on it doesn't overhang the heat sinks, it'll probably be OK.
    edited August 2013
    DaveHo wrote: »
    +1.
    It's hard to overheat a 555 unless you head toward clipping it--plus the heat is dissipated through the back fins that are fairly clear of the Pre-amp above, you're good. Dave is right about running the Carver into the Adcom for its tuner. That'll do you for now!
    Hook her up and fire away!
    cnh
    edited August 2013
    stretchl wrote: »
    Enjoy!
    A lot of that bite up top is more about what pre-amp you use with one than the amp itself.
    The pre Randy has may be a little bright on the high end, we'll see what he thinks.
    cnh
  • boston1450
    edited August 2013
    Thanks guys. I just looked on the Bay & i can pick up a very clean tuner for 1-150.00 so that will do fine. For now i will try it with the Carver just temporary for a little bit till next payday. I think im going to put the Amp by itself. I will know more when i start moving things around tomorrow. Thanks again. Big help from all :)
    Randy-Maine
    by David WMG
  • 84shovelhead
    84shovelhead Posts: 23
    edited August 2013
    was gonna go with one of these but pulled the trigger on a hafler that turned out to be a dud.good luck with it.They are workhorses for sure.
  • boston1450
    edited August 2013
    It sounds wonderful. I listened to N Young for 2 hours n drove my wife nuts. But i enjoyed it alot :)It not too harsh at all. Clean is all i can say. So real like Neil was sitting on a chair in front of me. Im not good at explaining how it sounds but it is perfect for what i was hoping to get from it..i ordered a tuner for it today-should be here this week. Just a plain jane adcom tuner.very pleased with Adcom.
    Randy-Maine
    by David WMG
  • boston1450
    edited August 2013
    cnh wrote: »
    +1.
    cnh
    thanks cnh. I have checked on heat every 15 mins. Not a problem at all. I kept the back away from wall about 8 inches. Seems fine & i am enjoying it. Wish i hadnt had waited so long :)
    Randy-Maine
    by David WMG
  • Bob in WI
    Bob in WI Posts: 155
    edited August 2013
    Alot of folks really like the Adcom sound. Have yet to hear it myself. Congrats.
