Using headphones with existing amp
EndersShadow
I cant find the post, or remember who talked about it, but someone posted a item that allowed you to take the outputs from an existing amp, connect them into this unit, and it would let you connect your headphones into it.
I thought it might be Zingo or Face, but it looks like I was wrong. So if you remember the post, or thread please let me know.
I thought it would be a cool product to use if you already like your existing tube or solid state amp, but want to be able to connect headphones into it.
In my case my TGP-II doesnt have a headphone output on it (and I am using coaxial for signal) and I dont want to have to buy a headphone amp just for it on top of the other amps I already have.
Thanks in advance.
Thanks in advance.
Post edited by EndersShadow on
You can make your own adapter, no special parts needed, as long as you're using a SS amp. For a tube amp, IIRC things will work better with resistors in parallel."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Just a little special math...
Depending on the headphone's impedance..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I found another option for folks out there, so thought I would bump this thread. Its the Vinyl Flat Can Opener.
Attachment not found.
Its getting some decent press as well.
Stereophile: http://www.stereophile.com/content/entry-level-31
AVSForum: http://www.avsforum.com/products/vinyl-flat-llc-can-opener"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Great name!
Yup, its on my christmas list for my vintage setup. I have no headphone capabilities for my 2 channel setup right now. It would require a little bit of work as obviously I have to disconnect my speakers and connect the Can Opener to get it working."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
