Pass X600.5 amps
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2013
    I think if I had that rig l would kneel down and bless myself with the sign of the cross las its truly an audio alter
    It's more like an audio space heater. I can't wait for winter to arrive. I'm surprised I never noticed the bug in the pre-amp display before. I don't used the CD player that much anymore, and usually let a CD play straight through.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2013
    BlueFox wrote: »
    Okay. While not an aesthetic solution, this works. These amps, for whatever reason, have a faceplate on either side of the meters. This means the meters are mounted on the amps proper, and there is an approximate 1/8" gap between the meters and the faceplate. This area is approximately 9 1/2" wide and 10 1/2" high. So I cut two pieces of cardboard slightly less than that size, and slid it into the slot created by the faceplate. Eureka! Problem solved. This is why I are an engineer paid the big bucks. :lol:
    But they don't sound as good with the big blue meters covered up.:cry:
    Congrats on your further descent into the rabbit hole.:cheesygrin:
  • BlueFox
    edited July 2013
    Au contraire, the late night, low light ambience is greatly enhanced, resulting in a much more pleasant experience, with the end result being greater musical clarity and depth.
    I wish we could change our names, since from now on my name is Mr. Frugal. :biggrin:
  • DarqueKnight
    edited July 2013
    Well, since you are frugal now, you will be happy to know that the webmaster can change your name at no charge.
