Need help speaker
ryu4000
ryu4000 Posts: 9
edited July 2013 in Troubleshooting
My right speaker louder then left i have try changing sides etc... also cris cross speaker wire aka put right channel to left and left channel to right
both speakers are like 3feet from center this what i got from running it
The speaker on right is a tad bit louder when listening to a movie audio track you can hear it if it has someone singing more of the voice will come towards the right and just small part from left.
FL -6.0
FR -6.5
C -6.5
SL -5.0
SR -6.0
here a picture of how i have it set now http://i.imgur.com/G0xRpyA.jpg
Post edited by ryu4000 on
  • rpf65
    rpf65 Posts: 2,127
    edited July 2013
    Could be mistaken, but it looks like that left front is toed in more than the right front. That could be your problem.
    Also not good to set them on cement blocks, I would get rid of the cement and use the floor.
  • ryu4000
    ryu4000 Posts: 9
    edited July 2013
    That's the only way to get it to ear height with the cement block cause they sit too low like below ear level.
  • custopper30
    custopper30 Posts: 252
    edited July 2013
    You have to understand that sound doesn't need to travel directly to your ear to make it sound the best..... If that is what you are trying to go for, might want to get headphones instead.
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • ryu4000
    ryu4000 Posts: 9
    edited July 2013
    I'm just going off what i hear from most sites like highdef avs etc.... they say to get it ear height but i didn't know you can still have them below ear level thanks for the tip.
  • boston1450
    boston1450 Posts: 7,758
    edited July 2013
    I would try putting them on the floor further out-toe them in a tad. See if there is a difference. There could possible be something wrong with your system. Worth trying different things. If you notice a big difference with them on the floor. Raise them up. Ive never used blocks-i use stands. Let your ears decide. Hope its a easy fix. Good luck
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    tonyb Posts: 33,066
    edited July 2013
    Also those speaker levels seem too low. Put everything back to 0 and adjust from there until you get the balance you want using the same track of music. Dump the cement blocks too.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited July 2013
    Maybe your hearing is better in one ear.
    Thats the case with me.
  • ryu4000
    ryu4000 Posts: 9
    edited July 2013
    I took the speakers off the blocks they sit on the floor they seem to be sounding a little better but still need to do some testing tonight im going watch evil dead 2013 to test it with that see if there balance out.
    @tony b i have use the spl meter they give as low as audyssey calibration gives me.
  • inson71
    inson71 Posts: 90
    edited July 2013
    Check to make sure the speakers in phase. Then, like tony said, put all levels back at 0. Measure the spl of each channel with radio shack spl meter to confirm that one speaker is in fact playing louder. If you don't have an spl meter, you can download an spl app on the IPad or smart phone. If all levels don't match, adjust up or down from zero until they all are at the same db level.
    Onkyo Pr-sc 5509
    Parasound 2250/Parasound 5125
    SVS PB 12 Plus
    Denon DBP-2012 Bluray
    Polk RTI 8, CSI 3, 4 FXI 3
    Sony 55" LCD
  • inson71
    inson71 Posts: 90
    edited July 2013
    Definitely get rid of cinder blocks. If you don't think the highs from the tweeters are reaching your ears, shim the front of each speaker to achieve the correct angle.
    Onkyo Pr-sc 5509
    SVS PB 12 Plus
    Sony 55" LCD
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2013
    In movies 90% of your sound comes from the center... Which is not at ear level at all.
    Main Surround -
