Can you recommend a good coffee maker?
pglbook
pglbook Posts: 2,258
edited July 2013 in The Clubhouse
My Bunn B10 coffee maker finally died on me yesterday.
I will need to buy a new coffee maker and was wondering if anyone could recommend a good one.
My budget is about $100 and my main criteria is that it brew a great cup of coffee. I am a big coffee drinker and do not need all of the bells and whistles (although programmable might be nice). I just want it to make a great cup of java. I liked the Bunn coffee makers a lot but this is the 2nd Bunn I have owned that did not last too long. They only last about 3-4 years in my experience.
I thought I would try a new brand other than Bunn.
Cuisinart gets good reviews. Does anyone have any experience with them?
Any other brands or models I should look at?
Thanks.
Post edited by pglbook on
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited July 2013
    http://www.cuisinart.com/m/products/coffee_makers/dcc-1200.html
    I think my cuisinart is just great. Nothing fancy just a really good coffeemaker.
  • nspindel
    nspindel Posts: 5,343
    edited July 2013
    Veronica at Starbucks. She's fantastic.
  • 11tsteve
    11tsteve Posts: 1,166
    edited July 2013
    i have the same one, been a pretty good machine. And I like the paperless filter.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • zane77
    zane77 Posts: 1,696
    edited July 2013
    The Cuisinart makers make a nice cup of coffee and I have owned about 3 of these. The only problem that I have found with them is the heater mechanism seems to get clogged with mineral deposits. Maybe if I had run some cleaning solution or vinager through it more often there would not have been as much of a problem. I have a KitchenAid that I picked up on sale at Costco 6 or 8 months ago and the handle is partially broken and when I went to order a new carafe, I saw on the Internet that this is a pretty common problem with this model. It makes great coffee but if I was going to get another one I think it would be a Cuisinart
    Two Channel
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited July 2013
    Had same issue with last 2 Bunn coffee makers, both crapped out after about 2 years. Ended up just buying a Keurig, it lasted about 2 years, the pump went bad and Keurig sent me a new one free of charge.
  • jflail2
    jflail2 Posts: 2,868
    edited July 2013
    I've enjoyed my Cuisinart as well (very similar model to what jeremy posted.) That being said, the carafe drives me nuts. The "pouring lip" is made in such a way that you have to turn the carafe literally upside down to get to that last cup of coffee in the AM.
    The carafe itself is nice, in that it retains the heat forever, the pouring just drives me batty. The paperless filter is indeed nice as well. And you can set up the timer to grind and brew your coffee at a certain time each AM.
    And it looks good on the kitchen counter if you have all stainless appliances....
  • headrott
    headrott Posts: 5,496
    edited July 2013
    Regarding the Bunn coffee makers. I would suggest (if you buy one in the future) that you purchase one assembled in the US vurses China. I had to go way out of my way to get the two I bought that were assembled in the USA, but both work flawlessly. The first one I bought (and still own/use) is about 5 years old and as I said works flawlessly. That's my .02.
  • Tornado Red
    Tornado Red Posts: 939
    edited July 2013
    The Cuisi in Jeremy's link, it's the one I have also. Consumer Reports best coffee maker a couple years ago, should be able to get it on sale for $70 or there abouts. Didn't much care for the permanent filter myself, thought it let some of the grinds through so I use bamboo paper ones. Can also be seen on the counter in 2.5 Men episodes :cheesygrin:
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited July 2013
    Capresso... look them up.. they are coffee perfection.
    Everything else is a waste of money.
    http://www.capresso.com/
    Garage | Polk Monitor 5B's
  • pglbook
    edited July 2013
    Thanks for all of the feedback.
    It looks like Cuisinart is the winner (nspindel, I am sure Veronica is fantastic, ha, but I do not care for Starbucks coffee; Mikey, the jura-capresso looks great but it's outside of my price range).
    Actually, the Cuisinart mentioned in many of the posts is the same one I was looking at, and leaning towards, when I did a little online research myself last night so I am glad a lot of people have had good experiences with it.
    Thanks again!
  • Systems
    Systems Posts: 14,873
    edited July 2013
    You should really consider adding these to your maker, as I find it offers a "cleaner", more aromatic cup of coffee:
    Just my .02
    Testing
    Testing
    Testing
  • jeremymarcinko
    edited July 2013
    I prefer the paper filters as well, the permanent one is nice in a pinch but does leave some sediment in the cup and more of a hassle to clean. Also I wouldn't recommend the one with the built in grinder, my father has that model and it is more difficult to clean than a separate grinder. I have the matching 12cup cuisinart grinder as well, its much easier to clean and control the grind. A tip on the mentioned mineral deposits damaging the coffeemaker and over all taste, only use bottled drinking water or reverse osmosis filtered water, helps a bunch. Rinsing the paper filter with water before use makes the coffee better as well. Put the new paper filter in the basket and fill it with water and just dump it out, removes most of the paper dust that can affect the flavor.
  • Msabot1
    Msabot1 Posts: 2,098
    edited July 2013
    My Cuisinart works well with unbleached number two cone filters....programmable and had a little LED that lights up when it's time to clean it....Great cup of Joe too...Gold Coast Blend!
    mhardy6647 Posts: 34,994
    edited July 2013
    pepster wrote: »
    Just my .02
    Oh, I don't know - I think I'd recommend lifting the ground and going two prong... enough grounds in coffee as it is.
  • dragon1952
    dragon1952 Posts: 4,907
    edited July 2013
    After owning a couple Cousinart and then a Bunn my wife picked this one up last week.
    http://www.bestbuy.com/site/Hamilton-Beach---BrewStation-12-Cup-Coffeemaker---Black/6581616.p?id=1218760172018&skuId=6581616
    have to say I was skeptical, considering the brand and low price, but it's the best one we've had. ALL of the parts that require cleaning are easily removed. No carafe, the brewed coffee is stored in a removable reservoir and dispensed by pressing the cup against the lever. You can program how long you want it kept hot from 0-4 hrs. Using the BOLD setting it makes a great cup of coffee. Even makes iced coffee if you are into that. We grind our own beans using a Baratza Virtuoso so YMMV depending on what you use.
  • Tornado Red
    edited July 2013
    Here ya go. Just upscaled my grinder to an automatic, fried my last small one. Others have mentioned the type of water they use, sure makes a difference. I use distilled, never have to clean the machine.
  • jeremymarcinko
    edited July 2013
    Yeahp thats the stuff right there^^
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited July 2013
    pglbook wrote: »
    Thanks.
    Have you tried calling Bunn? Ours started leaking after several years of use, I gave them a call to see if the maker could be repaired and they send me, free of charge, all the parts I needed to make the repair. Took every bit of 20 minutes to get back up and making coffee again. This repair has lasted several years and still going strong. Might be worth a call.
    billbillw Posts: 7,531
    edited July 2013
    I've been using a Capresso MT500 since 2005. Still works like the day it was new. However, I think the newer MT600 is not built as well as the older model. Production has moved to China. Overall, I prefer coffee makers with sealed thermal carafes and no bottom heaters. You get a good fresh hot brew, it doesn't keep using power and the coffee doesn't oxidize or get burnt from sitting on a burner for extended periods. Mine stays piping hot for at least 3-4 hours if full. Less if its half full. Usually, its more than long enough to get my morning coffee fix.
  • Tornado Red
    edited July 2013
    billbillw wrote: »
    bill makes an excellent point. I don't have a sealed carafe with the Cuisinart, but I have one waiting filled with hot water while the coffee brews. Once finished, I move it immediately to the carafe (after removing the hot water). Oxygen is the enemy to just brewed coffee, so it's a good idea to remove it from the burner like bill suggests and seal it up in the carafe.
    tonyb Posts: 33,072
    edited July 2013
    headrott wrote: »
    Experienced this myself too. Big Bunn fan if you don't mind the lack of features. Brews coffee like crazy...the old ones anyway. My older Bunn I had for 8 years.....newer Bunn didn't make it one year, garbage.
    Now have a Kitchenaid for 2 years now no issues. Coffee makers are a personal thing, like audio. :biggrin: There is no right or wrong coffee maker, but we all want one to last more than a year or two. Lets face it, at 100 bones, their throw aways when something goes wrong.
    It gets harder and harder to find anything made of quality to last these days. 100 bucks is about the minimum for a decent one.
  • Drenis
    Drenis Posts: 2,871
    edited July 2013
    tonyb wrote: »
    I don't agree with this at all! You can still buy your Black & Decker $20 or even $30 coffee makers along with other brands that do just that, brew coffee and will most likely die after a year. Great. But if I am going to spend $100 on a machine today, it should damn well be elite to those cheap $30 variants. Quality control has suffered over the years but morally I disagree. Can $100 not buy ANYTHING of quality anymore????? Sad...
    FWIW, I have been looking at this model as I want to avoid stopping at Tim Hortons every morning for a large coffee and breakfast sandwich and start taking my own coffee. I never make coffee on weekends or mornings because lack of free time and the fact we don't have a working brewer right now.
  • jimbo1421
    jimbo1421 Posts: 772
    edited July 2013
    I got tired of spending $50-100 every three years for a coffee maker. I tried going cheap, but the $16 Sunbeam made awful coffee. I bought the Capresso MT500 in 2006, $180. It's been making excellent coffee for seven years.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
    tonyb Posts: 33,072
    edited July 2013
    Drenis wrote: »
    I don't agree with this at all! You can still buy your Black & Decker $20 or even $30 coffee makers along with other brands that do just that, brew coffee and will most likely die after a year. Great. But if I am going to spend $100 on a machine today, it should damn well be elite to those cheap $30 variants. Quality control has suffered over the years but morally I disagree. Can $100 not buy ANYTHING of quality anymore????? Sad....
    Kinda the point Drenis.....you disagreed, then made my point. Confused I am. At my age that's pretty easy anyway. :cheesygrin:
  • Drenis
    Drenis Posts: 2,871
    edited July 2013
    tonyb wrote: »
    My excuse is I hadn't had my morning coffee yet when I posted!... :cheesygrin:
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2013
    tonyb wrote: »
    Drenis wrote: »
    LOL!:cheesygrin: Thanks for the laughs. I have been pretty stuck on Hamilton Beach for my coffee makers. MetLife let me pick a retirement gift when they laid me off, so I picked a fancy Krups machine. The damn thing didn't even make it a year before it stopped working! I tossed a several year old still working Hamilton Beach for that POS. Needless to say, I went right back to Hamilton Beach for a replacement. It does everything I need it to do for my one cup of coffee in the mornings.
  • Mikey081057
    edited July 2013
    I am using the Capresso Team TS and it is magnificent. It grinds and brews perfectly, and I order my beans from bluemacawcoffee.
    Lateley enjoying their Kona and JBM beans. Blows Starbucks away, and ends up being less costly in the long run. Agree totally on the thermal carafe as the hotplates use too much electricity and ruin the coffee.
    tonyb Posts: 33,072
    edited July 2013
    cfrizz wrote: »
    One cup ?? Your a light weight Cathy. :biggrin:
    If I don't have at least one POT, I get crabby. Must have some Brazilian blood in me because I can drink coffee all day and night and still sleep like a baby. You want a good one cupper...Nespresso. Think I spelled that right.
  • Tornado Red
    edited July 2013
    And now for something to brew in that new coffee maker... I like a couple of dark blends from Kicking Horse, 454 Horse Power or Kick A$$ are both good. Also like Pacific Pipeline as a medium blend. Their stuff is fair trade and organic, it's all good...:cheesygrin:
    https://www.kickinghorsecoffee.com/en/store/coffee
  • Mikey081057
    edited July 2013
