Overwhelmed!!!
JackOfBlades
I am way over my head right now when it's coming to choosing a receiver to power my new system I will be putting in my basement. Right now I have four rc85i's for surrounds, I am purchasing 2 Rti a5s for my fronts and the csi a4 for my center (haven't settled on which sub I want yet). I have no clue what type of receiver to get! I have read so many articles and forum posts my head is spinning. I would like to spend $1000 or under. Can someone suggest some good models for this set-up? Any help would be greatly appreciated. This is my first go-round with a home theater system.
Post edited by JackOfBlades on
Are you not getting the answers you want in your other thread?
Haha I just didn't know if I should post a pure rec question in the speaker section
I got some really good responses that led me to the Rti a5s and also some good sub choices..not much receiver help though...I'm truley clueless in that aspect.
Does anyone know about the pioneer elite sc 63?
If you can get it in your budget range then you should consider this one.Home Theater
You can't really go wrong with the SC models at any of their price points. That being said, Pioneer at one point in time only had a couple models and the choice was easy. The last couple years they've introduced many more models in the lineup and IMO it has watered down that SC Line, or at least made it more confusing. So while I'm confident the SC models are still great, I don't know which one to recommend.
I'd pick up a used older model SC like the 0X, 2X or 3X lines for half that price and use the rest of the money towards a really nice sub. Just my opinion, i'd also check out accessories4less as they always have good deals on avrs.
There are so many to chose from. So we understand the overwhelmed feeling.Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
JackOfBlades wrote: »Does anyone know about the pioneer elite sc 63?
Buy it, don't look back.Political Correctness'.........defined
President of Club Polk -
I'll second the accessories4less recommendation. I bought my Marantz receiver there and love it. They have great prices on refurbed Denons that I would probably look into if I were in the market. Just take the advice of everyone on here and get one with preouts. I was in love with the sound of my AVR for quite a while and now I only use it for powering the surrounds.Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
HK AVR635 | Polk R30 | Sony DVD/SACD Player -
I agree. The SC-63 has most of what you need. It was the third or fourth model from the TOTL Elite so a little less power, but all the features and processing you need and latest version of ICE amplification.
This will do you. Unless you wish to move higher up the food chain: SC 67 or SC 68?
Thanks for the feedback guys!
Make a list of what features you want out of an AVR. 100amps should be good enough to handle the speakers you have. Also make sure you can hook an amp up to it for more power if you so wish.Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I spoke with a couple of buddies that know a lot more than I do and they said the sc 63 would be good for so that's what I ended up purchasing...pretty pumped to get everything set up...now I just need to decide between the a5s or spend 200 more for the a7s. I listened to them both today and I think I'm going to go with the a7s
I would go A7'sAVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Congrats on the 63 it's a nice avr, and +1 on the A7's you'll be glad you did it.
A7'sMarantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes: -
Congrats on the receiver, you won't regret it. That said, once you have it in hand, read the manual cover to cover, twice. Modern receivers take a bit of setup to get right and most complaints over sound is usually a setup issue.HT SYSTEM-
lsi 9's -
Will do thanks Tony
@Jackofblades -Any updates on your setup? Do you feel you made the right choice?Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000 -
The Pioneer has a "monitor" out ( may be the hdmi out), use it. It will let you set up the unit like a computer bios. The pioneer comes with a auto tune mic called "mcacc", use it to setup your systems after you have installed all the speakers.B&W CM9Classé Sigma
I'm looking for a newer AVR and will the Pioneer Elite SC-63 power a LSiC and LSiFX surrounds? I currently am using an external amp to power the the towers.
Thanks.
