Repair Onkyo 805
sandworms
sandworms Posts: 1,043
edited June 2013 in Electronics
my 6 year old receiver finally took the hdmi crapper that most other Onkyo's do, just wondering if I should fix it for the $260 united radio wants or use it for my boat anchor, what do you guys think?
Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
Post edited by sandworms on
  • jon s
    jon s Posts: 905
    edited June 2013
    That's not the price to replace the board, it's to repair it... Onkyo wants several hundred for a new board. If you are competent, you can fix it yourself. You have to replace the caps on the board. The caps dry out as they are rated for only 85 degrees and the baord gets super hot, causing them to fail. Go to AVS Forum for more info, or google HDMI Onkyo failure.
    edited June 2013
    Although I do not have the skills to do this, evidently most Onkyo HDMI failures are due to capacitor failures as described in this repair video on the TX-SR606. Not sure what differences exist between 805 board and the 606 but I doubt they are that different.
    The fix is actually NOT that expensive if you can do it yourself. And all Onkyo had to do was PUT BETTER grade, HIGHER temp caps in there to begin with in order to address those failures...but they were JUST TOO CHEAP to do so!
    http://www.youtube.com/watch?v=gj0x5S9ez5U
    cnh
  • brgman
    brgman Posts: 2,859
    edited June 2013
    You may want to heck out a place like accessoriesforless and see what factory refurbs they offer
    Not sure if I would spend much on a 6 yr old unit when you might getaway current refurb for a bit more
    Good luck
    I’M OFFENDED!!!!
  • sandworms
    edited June 2013
    That was my thinking, not worth that amount to fix. I don't have any soldering skills, so I shipped it to their auth serv center. It's just been such a great performer for 5 years, I hate to think it's a total loss. Oh well, anyone need a paper weight?
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Cassidy
    Cassidy Posts: 87
    edited June 2013
    The display light went out on my 805 and I plan to operate on it soon. Supposedly it just needs a new resistor. You might be able to sell your's for parts and get some cash. I know AVS has a dedicated thread for the 805.
    edited June 2013
    Cassidy wrote: »
    How does a display light on that go out so SOON? I have an old Kenwood AVR that was bought in 1990 that I still use outside that STILL has a FUNCTIONING display. 23 years! Those panels last a LOOOONGGG Time! Or are supposed to!
    My Pioneer is 10 years old. No problem there, either!
    cnh
  • jon s
    jon s Posts: 905
    edited June 2013
    Technology in audio equipment is changing too fast for manufacturers... They have to come out with new circuitry to deal with different HDMI versions (1.1, 1.2, 1.3, 1.3a, 1.4 etc), new decoding formats (Dolby Digital, Dolby Digital+, Dolby True HD, DTS, DTS HD Master, Neo, PLIIx, you get the drift).
    Then there is the multitude of video chips, HQV, Marvell, Faroudja, ABT, etc), the DACs (Cirrus Logic, ESS, Burr-Brown, Wolfson). All the component makers must create the parts, make sure it is bug free (it never is). Blu-Ray players must be updated often to compensate for different Java languages.
    Every year, the hardware in the AVRs must be completely redesigned on new parts that have not been released, hoping that it will work on release. Implementing the latest and greatest is not cheap. They have to cut corners somewhere, and sometimes it bites them in the a**. They think something should be fine and when it doesn't, you have the problems like Onkyo, Pioneer, Yamaha and others all have.
    It's a lot different than your 1990 Kenwood AVR which only has Dolby Digital and s-video outputs.
  • sandworms
    edited June 2013
    I declined the repair, I'll just try to replace the caps myself
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • jon s
    jon s Posts: 905
    edited June 2013
    be careful... i think there's a solder joint that has to be joined before removing the board... It's near one of the edges and is labeled...
  • sandworms
    edited June 2013
    Thanks, I'll look for that
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    billbillw Posts: 8,104
    edited June 2013
    I had an 805. HDMI-3 started failing. I replaced EVERY cap. I am good with the soldering iron. Unfortunately, the re-cap job did not help.
    I think the 805 fails in other ways (unlike the majority of Onkyo receivers).
    If I were you, I'd just use the optical/coax inputs and buy an external HDMI switch. You give up the lossless audio, but gain reliability. I made the mistake of selling mine and forked out a bunch of money for a new Yamaha A3010. It doesn't sound any better than the Onkyo used to, and guess what...the HDMI failed on it too! Its under warranty, but it doesn't give me a lot of faith long term.
    HDMI is just not a very reliable interface. Too sensitive.
    I wish I would have kept my 805. Selling it turned out to be a nightmare too.
  • WLDock
    WLDock Posts: 3,073
    edited June 2013
    sandworms wrote: »
    I do? LOL
    As stated, many of the issues are with bad caps. If you don't think you can fix it try to find a local tech that can give you a good price on replacing the caps for not too much money..maybe one that does side work. If that does not fix it then it might be a hard choice to spend more on it.
    Myself, I'm set on getting one of the older used Pioneer SC units. I had a line on one an SC-25 for $450 shipped HOWEVER I tried to pick up this 805 unit for $150: http://charleston.craigslist.org/ele/3820539798.html...but the guy did not want to ship. Would have been the most BANG for the buck for my needs. On the flip side...if I already had an 805 I would have a hard time spending $260 on a repair plus shipping cost given the stuff that one can find in the used market. However, I have a slight advantage.... I'm a tech and can do minor repair work....however, I have a couple of RT3000p amps that are kicking my butt! Been replacing parts left and right. I may have to have someone better look at them. I think they boards are bad which is what Polk told me they have seen....they tend to crack real easy. So...sometimes repairs are simple...not so much other times. :wink:
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
