CSI A6 vs anything else
Poolgod69
Poolgod69 Posts: 184
edited June 2013 in Speakers
I have the A9's and looking for the center channel.
I went to Fry's last night and compared the RTi A6 and A4 center channels. Both sounded great but completely different. The A4 does not have much base, really nice mids/highs. The A6 was louder at the same setting, but lacked the mids since it has 2 51/4" woofers and 1 tweeter, essentially it sounded like a 2 channel speaker. I am concerned the A6 center would provide to much added bass when it is not needed and not enough of the mids. Since the center will provide at least 60% of the sound for movies I am unsure if it will be ok.
If anyone else has the A6 how is it? Would you recommend it? Should I go outside the RTI series and get a different center but stick with Polk? If so, any suggestions?
Brian
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
Post edited by Poolgod69 on
  • Geoff4rfc
    Geoff4rfc Posts: 2,805
    edited June 2013
    You put RTiA6 in your paragraph but I'm sure you meant the CSiA6 as in your title.
    I would stick with that center for your A9's. It can be set to small and sounds great.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
  • Poolgod69
    edited June 2013
    Yes I meant the CSi A6
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    F1nut Posts: 51,673
    edited June 2013
    Get the CSi A6.
  • B Run
    B Run Posts: 1,888
    edited June 2013
    I've got the older version but my Csi5 matches my Rti12's perfectly, get the A6 you'll be glad you did.
  • rpf65
    rpf65 Posts: 2,127
    edited June 2013
    I have the A4, matched to the A5's. Works really well with them at +1.5 db.
    Given that, I would strongly suggest the A6 over the A4. I think that once the front stage is running, at most you would have to dial the center back a little, and be happy with the sound.
    tonyb Posts: 33,065
    edited June 2013
    Get the CSi A6.
    True dat.....the only other centers that to me don't stray too far from the Polk sound are those from Def Tech, maybe Legacy, even the P-diddy's. It is however optimal to keep the front 3 the same sound signature.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2013
    I have the Csi A6 I got it from Newegg for $250 F/S no tax.
    The Polk Audio CSI A6 boasts dual 6.25" polymer composite dynamic balance drivers and a 1" dynamic balance silk/polymer composite dome tweeter
    I use it with the SDA 2.3tls I have the CS2 Series 2 but I like this better.
    I think the 5 is the same just an older model. See below.
  • PolkieMan
    edited June 2013
  • Thorton
    Thorton Posts: 1,324
    edited June 2013
    Get the CSi A6.
    +1. I have it matched with the A9's. Sounds great for movies.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited June 2013
    Thorton wrote: »
    Ditto.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Poolgod69
    edited June 2013
    Well ok then. I guess I will stick with the A6 :cheesygrin:
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    you won't be sorry the 6 is the way to go.
    Two Channel
  • oleon621
    oleon621 Posts: 178
    edited June 2013
    CSI5 would work fine too. I have one setup with RTIA7s and they're a perfect match. I got one brand new from Frys for $200 a while back. Good luck
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
  • doggie750
    doggie750 Posts: 1,160
    edited June 2013
    I have csiA6 & csi40. Get the csi40 if u still can, mid tone advantage than its successor (A6).
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • PolkieMan
    edited June 2013
    Why is that?
    doggie750 wrote: »
  • Poolgod69
    edited June 2013
    PolkieMan wrote: »
    Why is that?
    Thank you for asking!
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • xftman
    xftman Posts: 153
    edited June 2013
    +1. A9 matches A6.
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • doggie750
    edited June 2013
    Poolgod69 wrote: »
    My experience and the nature of the beast. See the spec for both, link right below.
    http://www.shopping.com/xSBS-Polk-Audio-CSi40-Polk-Audio-Polk-Audio-CSI-A6-AM6615-A-Center-Channel-Speaker-Black-Oak~PRDLT-20066048-48807212?sb=1
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • PolkieMan
    edited June 2013
    the 40 is not as deep or as long could be a plus. they still look fairly close. it's somewhat of a toss up best deal color, style, placement "your own ears" the main thing.
    doggie750 wrote: »
  • David R
    David R Posts: 134
    edited June 2013
    How does your system sound without the center?
    Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
  • David R
    David R Posts: 134
    edited June 2013
    If you picked up the CSI 6'a how does your system sound now compared to how it sounded before?
  • specd_out
    specd_out Posts: 505
    edited June 2013
    One more for the a6. I went from an a3 to an a6. The a6 is a marked improvement over the a3. Its a huge speaker make sure you have the space.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • mu1166
    mu1166 Posts: 172
    edited June 2013
    I have to join the crowd in saying that the A6 was a huge improvement over the A4 when I changed it out in my system. It sounded excellent next to my A9's. I would highly recommend it.
    AVR: Pioneer Elite SC-67
    Mains: Polk LSiM707
    Center: Polk LSiM706c
    Rear: Polk LSiM702F/X
    Sub: SVS PC12 Ultra
    TV: Panasonic VIERA TC-P60GT50
    DVD: Xbox 360
    NMT: Popcorn Hour C-200
    EndersShadow Posts: 17,687
    edited June 2013
    If there is too much bass you can always adjust the crossover up to cut more out, you cant add more bass to a speaker not capable of producing it.
  • doggie750
    edited June 2013
    OP, with ur system u can stay within the Polk guidelines. Either A6 or the 40 is ur best option. If want to save some cash and a little better performance, then Csi40 is the winner. If u want to blend with the looks then A6.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • Poolgod69
    edited June 2013
    I have a crappy LG center from my bedroom 5.1 and that is fitting the want for right now. But without the center in HT is ok but I will just turn the TV volume up to go along with the speakers.
    For music I do not use the center at all.
    I am definitely going to get the A6 and I am now on the look out for a good deal.
    Thank you for the input.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2013
    B Run wrote: »
    Same here. CSiA6 all day, errr' day.
  • doggie750
    edited June 2013
    OP, just an FYI. Ebay has the csi40 for $130 shipped.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
