CSI A6 vs anything else
I have the A9's and looking for the center channel.
I went to Fry's last night and compared the RTi A6 and A4 center channels. Both sounded great but completely different. The A4 does not have much base, really nice mids/highs. The A6 was louder at the same setting, but lacked the mids since it has 2 51/4" woofers and 1 tweeter, essentially it sounded like a 2 channel speaker. I am concerned the A6 center would provide to much added bass when it is not needed and not enough of the mids. Since the center will provide at least 60% of the sound for movies I am unsure if it will be ok.
If anyone else has the A6 how is it? Would you recommend it? Should I go outside the RTI series and get a different center but stick with Polk? If so, any suggestions?
Brian
Brian
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Post edited by Poolgod69 on
You put RTiA6 in your paragraph but I'm sure you meant the CSiA6 as in your title.
I would stick with that center for your A9's. It can be set to small and sounds great. -
Yes I meant the CSi A6Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Working on updating my set up :rolleyes: -
Get the CSi A6.Political Correctness'.........defined
President of Club Polk -
I've got the older version but my Csi5 matches my Rti12's perfectly, get the A6 you'll be glad you did.
I have the A4, matched to the A5's. Works really well with them at +1.5 db.
Given that, I would strongly suggest the A6 over the A4. I think that once the front stage is running, at most you would have to dial the center back a little, and be happy with the sound. -
Get the CSi A6.
True dat.....the only other centers that to me don't stray too far from the Polk sound are those from Def Tech, maybe Legacy, even the P-diddy's. It is however optimal to keep the front 3 the same sound signature.HT SYSTEM-
lsi 9's -
I have the Csi A6 I got it from Newegg for $250 F/S no tax.
The Polk Audio CSI A6 boasts dual 6.25" polymer composite dynamic balance drivers and a 1" dynamic balance silk/polymer composite dome tweeter
I use it with the SDA 2.3tls I have the CS2 Series 2 but I like this better.
I think the 5 is the same just an older model. See below.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
http://www.ebay.com/itm/Polk-Audio-CSi-A6-Cherry-Open-Box-2-Way-Center-Channel-Speaker-/171027147932?pt=Speakers_Subwoofers&hash=item27d2032c9c
http://www.ebay.com/itm/CSi5-Cherry-Center-Channel-Polk-Audio-RTi-Speaker-/230925695410?pt=Speakers_Subwoofers&hash=item35c43e79b2POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
Well ok then. I guess I will stick with the A6 :cheesygrin:Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
you won't be sorry the 6 is the way to go.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
CSI5 would work fine too. I have one setup with RTIA7s and they're a perfect match. I got one brand new from Frys for $200 a while back. Good luckFront- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000 -
I have csiA6 & csi40. Get the csi40 if u still can, mid tone advantage than its successor (A6).Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
Why is that?I have csiA6 & csi40. Get the csi40 if u still can, mid tone advantage than its successor (A6).POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Thank you for asking!Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
+1. A9 matches A6.MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
My experience and the nature of the beast. See the spec for both, link right below.
http://www.shopping.com/xSBS-Polk-Audio-CSi40-Polk-Audio-Polk-Audio-CSI-A6-AM6615-A-Center-Channel-Speaker-Black-Oak~PRDLT-20066048-48807212?sb=1Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
the 40 is not as deep or as long could be a plus. they still look fairly close. it's somewhat of a toss up best deal color, style, placement "your own ears" the main thing.My experience and the nature of the beast. See the spec for both, link right below.
http://www.shopping.com/xSBS-Polk-Audio-CSi40-Polk-Audio-Polk-Audio-CSI-A6-AM6615-A-Center-Channel-Speaker-Black-Oak~PRDLT-20066048-48807212?sb=1POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
How does your system sound without the center?Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
If you picked up the CSI 6'a how does your system sound now compared to how it sounded before?Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
One more for the a6. I went from an a3 to an a6. The a6 is a marked improvement over the a3. Its a huge speaker make sure you have the space.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
I have to join the crowd in saying that the A6 was a huge improvement over the A4 when I changed it out in my system. It sounded excellent next to my A9's. I would highly recommend it.AVR: Pioneer Elite SC-67
Mains: Polk LSiM707
Center: Polk LSiM706c
Rear: Polk LSiM702F/X
Sub: SVS PC12 Ultra
TV: Panasonic VIERA TC-P60GT50
DVD: Xbox 360
NMT: Popcorn Hour C-200 -
If there is too much bass you can always adjust the crossover up to cut more out, you cant add more bass to a speaker not capable of producing it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
OP, with ur system u can stay within the Polk guidelines. Either A6 or the 40 is ur best option. If want to save some cash and a little better performance, then Csi40 is the winner. If u want to blend with the looks then A6.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
I have a crappy LG center from my bedroom 5.1 and that is fitting the want for right now. But without the center in HT is ok but I will just turn the TV volume up to go along with the speakers.
For music I do not use the center at all.
I am definitely going to get the A6 and I am now on the look out for a good deal.
Thank you for the input.Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Same here. CSiA6 all day, errr' day.Shoot the jumper.....................BALLIN.............!!!!!
OP, just an FYI. Ebay has the csi40 for $130 shipped.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
