I want to paint it black....
echoofformless
echoofformless Posts: 28
edited June 2013 in Speakers
Yes I know, this will be sacrilegious and cringeworthy for many of you, me included...but it must be done.
I have a pair of Monitor 70s in black with silver facing. The silver facing looks really out of place in my decor. I mean really, really out of place.
So I have decided that I need to paint the faces black (so they will look like the Series 2).
What kind of paint should I be using, and what method? I'm assuming a low gloss oil based enamel. Should I go through the hassle of taking out the drivers in order to spray the coat, or do you think I could get away with using a pad/brush?
Post edited by echoofformless on
  • Zeros
    Zeros Posts: 940
    edited June 2013
    I think the million dollar question you are trying to ask is "where can I buy black paint", right? I think there is a thread about that here somewhere.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited June 2013
    Just keep the grills on'em.
    Definitely remove the drivers. Sand them a bit. Id probably use rustoleum spray paint in light coats. I painted a stainless steel motorcycle exhaust once with that stuff and lasted until I Sold it anyway which was at least a couple years later.
  • Habanero Monk
    Habanero Monk Posts: 715
    edited June 2013
    Pull the drivers out. Tape off the sides and top. Scuff the existing baffle with 600 grit. Buzzcan with Rust-o-leam primer and a finish enamel of your choosing. Clear coat buzz can and hit with buffing compound. Wait a few days between paint and clear coat for the paint to fully cure.
  • madmax
    madmax Posts: 12,434
    edited June 2013
    Vinyl, the final frontier...
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2013
    madmax wrote: »
    You beat me to it...classic.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,924
    edited June 2013
    First thing, you need to know what product was used to color the Titanium faces. I suggest you CALL Polk to inquire. There are a lot of products that will not accept a different type of product applied on top of them, so just grabbing a can of something could lead to a major disaster. Better yet, leave the grills on. They are there for a damn good reason.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2013
    I like mine naked too.... Guess that isn't good??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Upstatemax
    Upstatemax Posts: 2,777
    edited June 2013
    I plainted my Monitor 70 faces black and they came out great.
    I just taped off the cabinets, sanded the surface to rough it up. Primed it, re-sanded and then several lite coats of black satin paint.
  • Geoff4rfc
    Geoff4rfc Posts: 2,927
    edited June 2013
    vmaxer wrote: »
    There's nothing wrong with leaving the grills off. It's designed to protect the drivers while letting sound come through. If your drivers are in no danger of being hit with anything, no worries.
    Set up: 11.2 HT + 2ch
  • Geoff4rfc
    edited June 2013
    The series II has a matt finish on the faces. The gloss finish might look pretty cool.
    A few good suggestions have been given here, rough up the surface a tad bit with fine grit sand paper after you've removed the drivers and taped off the inside of the driver openings and where the face meets the cabinet and give it a go.
  • echoofformless
    edited June 2013
    Thanks everyone!
    FYI - I do leave the grills on, but they don't fully cover the silver and it just sticks out like a sore thumb in my decor.
  • bondslex
    bondslex Posts: 109
    edited June 2013
    No problem.
    LSI 15
    LSI C
    LSI FX
    80 fx ls for atmos
    Velodyne SPL-10
    Marantz 7012
    Panasonic 9000
    JVC 420
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2013
    bondslex wrote: »
    No problem.
    You sure have made a lot of useless posts tonight. To much crank?
  • headrott
    headrott Posts: 5,496
    edited June 2013
    BlueFox wrote: »
    Observe his post count.
  • RamZet
    RamZet Posts: 792
    edited June 2013
    I bet that rubber paint in a spray can would look cool.
    B&W CM9Classé Sigma
  • Poolgod69
    Poolgod69 Posts: 184
    edited June 2013
    I think you are just looking for a reason to get new speakers...lol.
    Just go for it!!! :cheesygrin:
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
  • echoofformless
    edited June 2013
    Haha if I got new speakers, I would just be replacing the normal Monitor 70's with the Series 2 versions that are all black. I would lose a bit on the resale of what I already have.
  • nodes
    nodes Posts: 2
    edited June 2013
    I would use Plasti Dip, can be bought at Home Depot for less then $6 and is peelable if you do want to go back to factory look.
    F1nut Posts: 51,924
    edited June 2013
    nodes, welcome to Club Polk. That said, your idea is horrible. Same goes for RamZet's.
    F1nut Posts: 51,924
    edited June 2013
    vmaxer wrote: »
    They are designed to sound their best with the grills on. Removing the grills will present a slightly brighter sound.
  • timk65
    timk65 Posts: 40
    edited June 2013
    Thinking about painting my 5JR's since the vinyl is starting to peel off and look like hell. In anycase I would pull of the vinyl, use a filler to get the cabinet glassy smooth, and then use Krylon on it.
