Preamp with DAC section
13»
  • zingo
    zingo Posts: 11,258
    edited June 2013
    I just drank the cool-aide and bought a pair of these for the Dodd Buffer to replace the Sonicaps:
    heiney9 Posts: 25,630
    edited June 2013
    I think you will like the Kool-Aid. Sonicaps are excellent as well. Perhaps these will just be another flavor of Kool-Aid rather than "better" Kool-Aid. I haven't used any of the top end Clarity's but I have used the PW, PX and SA all with great results.
  • zingo
    zingo Posts: 11,258
    edited June 2013
    The Sonicaps with Plat bypass are not my first choice, but came with the unit and have a solid sound. I've used the ClarityCaps up through the ESA, but not the MRs yet. I was very tempted to just go with the ESA as it's a great cap regardless of price, but this buffer already has upgraded everything else, so I'll go all in with the caps too.
  • Face
    Face Posts: 14,340
    edited June 2013
    heiney9 wrote: »
    The MR is a completely different animal. The ESA is just like the SA, but better.
  • zingo
    zingo Posts: 11,258
    edited June 2013
    Just installed the MRs (a very tight squeeze), and I'm playing with battery power verses a high current power supply for noise and dynamics.
  • zingo
    zingo Posts: 11,258
    edited June 2013
    High current power supply is just as quiet as battery power, but a little more dynamic, and less hassle than a battery and charger system. I'll be putting the battery on the shelf as the power supply has no noise (electrical or mechanical), low heat, and no worry. No having tried this Dodd battery supply, and the Red Wine Audio battery supply, I have not found a benefit of battery power if any one piece of your system is connected to A/C; including the source.
