doesn't seem worth while
Willow
Willow Posts: 11,371
edited June 2004 in Speakers
Manufacturer
Model Polk Audio PSW202 10" and Subwoofer Velodyne CHT-10 10"
Price $349.99 $449.99
Power Capability 100 Watts (polk)375 Watts(vel)
Amplifier Power 100 Watts(polk) 375 Watts/150 RMS(vel)
Frequency Response 30 Hz - 180 Hz (polk) 28Hz - 120Hz (vel)
they have one as open box but it hardly seems worth while does it ?? am I missing something ???
    F1nut Posts: 52,406
    edited June 2004
    What doesn't seem worthwhile?
    Don't use specs alone when looking at gear, you have to listen.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2004
    I'm not sure what you're getting at....but if they're trying to charge $349 for a 202 then it's definitely NOT worthwhile...
  • dcarlson
    dcarlson Posts: 1,740
    edited June 2004
    That's loony Canadian funds. ;)
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Willow
    edited June 2004
    the prices are CAD thats why they might seem high..I have a 202 but my wife saw the velodyne cht10 open box....I don't know if its better to go with the cht or keep the 202 and down the line buy a svs or hsu.... if I dont get the cht maybe upgarding the mains rti4 to rti6 might be a better upgrade than the sub
  • bokdaddy
    bokdaddy Posts: 176
    edited June 2004
    Maybe a correction to the PSW202 specs would help your decision. Here's the correct range:
    Overall Frequency Response 40 - 200Hz
    Lower -3dB Limit 45
    Upper -3dB Limit 180
    Crossover Variable 80 - 200Hz
    Inputs Speaker level and line level
    Outputs Speaker level pass-through
    40hz - 200hz
    Home:
    Denon AVR-1803
    Polk CSi30
    Polk RTi70
    Polk RTi28
    Polk PSW-303
    Car:
    Kenwood KDC-BT945U
    RF Punch P400-4
    Polk MM6501
    Polk MM651
    RF Punch P300-1
    Boston Acoustics G312-4
  • Willow
    edited June 2004
    damn futurshop website they can never keep the specs straight!!
    well the diff between 28 and 40 is a big gap.....hmmm maybe it is worth it....
  • jefft1314
    jefft1314 Posts: 169
    edited June 2004
    the cht 10 is in the same league as the psw 404. You can't compare the 202 to it, and yeah, it probably is a worthwhile upgrade if you're unsatisfied with your bass, and I think you'll probably notice a bigger difference then upgrading your rti 4's to rti 6's, but that's just one man's opinion.
  • Willow
    edited June 2004
    its not that Im not satisfied I know Im missing out on how low the bass can go...hmmm stuck now..what to upgrade first....fronts or sub
    If I go the main route wont the csi3 seem a tad whimpy with the rti6s??
  • AsSiMiLaTeD
    edited June 2004
    Not at all...
    why not just hold on to your money for a bit and upgrade to a HSU or SVS?
  • Willow
    edited June 2004
    guess the upgrade bug is itchin real bad...maybe keep as is and getter a much better sub a bit later...shoot
    See I'd replace my r10's in rear with the 4's and 6's up front , the r10s are good but not up to par with the rest of the system
  • johnny_utah
    johnny_utah Posts: 117
    edited June 2004
    Then your speakers will be voice matched and all grills will match being from the rti/csi lines.
    I have the rti6's with the csi3 in the center and fxi3's in the rear and the sound stage is great.
  • Willow
    edited June 2004
    maybe I should just look at some fxi3's for the back and keep my 4's for now
  • michael_w
    michael_w Posts: 2,813
    edited June 2004
    I've found that if you just hang onto your cash for a little while you usually end up finding a better deal.... Like I was almost going to buy a pair of rti6's for 500 cdn (before tax) but I held off.... Week after that I had a pair of lsi7's coming my way for somwhere between 400 and 500 cdn. Just and idea.
  • johnny_utah
    edited June 2004
    i think the fxi3's are awesome! The rti6's should add a little something to the front sound stage over the 4's though.
    Tough choice. I say get the fxi3 (greater improvement over current rears IMO), then tell your wife you want the 6's for fathers day. If you don't have kids, nows a good time. If you don't have a wife, back to a tough choice.
  • Willow
    edited June 2004
    I think thats what Im going to do I was just wondering what would be the best upgrade to do first incase I see a or many deal(s)
  • MSkeezer
    MSkeezer Posts: 1,183
    edited June 2004
    The Velodyne isn't a bad sub at all. I had the CHT-8, and I thought it was a definite improvement over the 202. I've only listened to the 10 at Circuit City, and I thought it did an admirable job with movies. It's much, much better than the 202, and it's right up there with the PSW404.
