Tweeter terminal connector in CS400i
HTguru1982
I had to swap out tweeters in my CS400i and when pulling off the negative connector, it snapped on me. So it looks like I need a .110 crimp on or soldier connector.
I need something similar to this but no one around here carries them, at least not in the size I need: http://www.radioshack.com/product/index.jsp?productId=12547293&clickid=prod_cs
Can they ordered from Polk?
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
Try Parts Express.Political Correctness'.........defined
President of Club Polk -
Sounds crazy but I would try Napa.HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC. -
Thanks but I already looked. The connector that they have is too long. The tweeter in the CS400i sits in a recess that unfortunately isn't very deep which is why I'm having trouble finding an appropriate connector. Polk uses smaller 90 degree connectors that allow the tweeter to sit comfortably in that recess. Everything I've looked is simply too large.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Subwoofer: SVS PB10-ISD -
I think this is what you are after .110 90 degree angled flag terminals:
http://www.digikey.com/scripts/dksearch/dksus.dll?pv298=375&FV=fff40016%2Cfff8041a%2C10600008&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
http://www.newark.com/te-connectivity-amp/62336-1/terminal-flag-rcpt-22-18-crimp/dp/05H95192.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Thanks WLDock, that should work. I had been looking for the 90 degree angled terminals but couldn't find any in that size. Thanks!I think this is what you are after .110 90 degree angled flag terminals:
http://www.newark.com/te-connectivity-amp/62336-1/terminal-flag-rcpt-22-18-crimp/dp/05H9519Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
