clairty vs sonos caps
soundfreak1
soundfreak1 Posts: 3,414
edited June 2013 in Vintage Speakers
Opinions welcome as to sonos vs clairity caps for pair of rta12c's.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • drumminman
    drumminman Posts: 3,396
    edited May 2013
    Do you mean Clarity and Sonicaps?
    pitdogg2 Posts: 27,079
    edited May 2013
    you cannot go wrong with either. So let price and availability be your guide.
  • soundfreak1
    edited May 2013
    Just found madisound is having a close out on clairty SA caps (40% off) sooooooo. Claitry SA's will do just fine!.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • lanchile
    lanchile Posts: 560
    edited May 2013
    Go for them!!!!they are very good caps!
    Make it simple...Make it better!
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Also, diycable.com is going out of business and have some Carity and Erse caps on closeout.
    http://www.diycable.com/main/default.php
  • zingo
    zingo Posts: 11,258
    edited May 2013
    ClarityCaps are awesome
  • canadianicon25
    canadianicon25 Posts: 200
    edited May 2013
    is the claritycap blowout listed somewhere on madisound's website?
  • StantonZ
    StantonZ Posts: 452
    edited May 2013
    There's a link at the top of the cap page (looks out of place). They're for the high-voltage caps, which are large. I don't regret getting my SoniCaps.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • soundfreak1
    edited May 2013
    The closeout is on the SA'S and ERSA 600+ Volts only.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited May 2013
    Picked up all caps ( clairty SA ) for the rta12c's for 336.88 from. Madisound at 40% off. Now, wire, terminators, risistors, t-nuts, ect, ect.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • drumminman
    edited June 2013
    If you got enough to do both the upper and lower Xovers you made out like a bandit!
    Toolfan66 Posts: 18,082
    edited June 2013
    Looks like Madisound is clearing out its MR's.
  • soundfreak1
    edited June 2013
    drumminman wrote: »
    Got them all:
    8x 25uf
    8x 2.2uf fof the 27uf's
    8x 2.2uf. For the 4.4's
    2x 50uf
    2x 4.7's for the 55uf's
    All for 336.86
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,809
    edited June 2013
    I'll presume that is suppose to be 2.7uF and not 27uF. Your value choice is minus 18% out of spec and you will hear that.
    Again, I'll presume that is suppose to be 5.5uF and not 55uF. Your value choice is minus 14% out of spec and you will hear that too.
  • soundfreak1
    edited June 2013
    No... 25uf and 2.2 will give me 27.2 for the 27 uf caps
    The 50 uf and the 4,7 for the 55uf
    8x 2.2 will give me the 4x 4.4uf
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • canadianicon25
    edited June 2013
    yup. parallel wiring.
  • westmassguy
    westmassguy Posts: 6,850
    edited June 2013
    2.2 X 2 is fine, but 25 +2.2 and 50 + 4.7 really isn't the best way to parallel caps. A 12 and a 15, would have been better, and a 25 and 30 for the other. Always try to keep the values close when making up an odd size.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • soundfreak1
    edited June 2013
    I will try this again, i need 8x 27. uf caps
    4x 4.4 uf caps
    2x55uf caps.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • StantonZ
    StantonZ Posts: 452
    edited June 2013
    I didn't want to say anything because he was after a good deal on the caps, but I agree. I actually paid (Sonic Craft) a little extra get a 34 uF cap instead of putting 2x17 uF in parallel, and I'm really glad I did because it would have been difficult to fit them on the board (it was hard enough to fit the one).
    F1nut Posts: 51,809
    edited June 2013
    Ah my mistake, sorry.
    However, westmassguy is right. By using small values with much larger values the small value cap acts as a bypass cap, which will impart unwanted artifacts to the sound.
  • cincycat13
    cincycat13 Posts: 888
    edited June 2013
    I see you went with the Clarity SA. The sale has me considering modding the maple LSi9s I have. Any thoughts on the ESA vs SA with the sale pricing?
  • soundfreak1
    edited June 2013
    cincycat13 wrote: »
    Im not sure of the diff. myself. Went with tje SA'S due to past experience with them and the 40% off sure helped as well! Saved about 150.00 on the order ( RTA'S have 14 caps in them! )
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,809
    edited June 2013
    40% off doesn't mean squat when you don't get the right stuff.....just saying.
  • cincycat13
    edited June 2013
    wow...that was fast...
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2013
    I have, on occasion, disagreed strenuously with F1nut.
    In this case, he's ABSOLUTELY CORRECT.
  • soundfreak1
    edited June 2013
    Ok doea this sound better:
    Esa 33 & Esav22 fir the 55 cap
    Esa 2.2 + Esa 2.2 for the 4.4
    And in yhe Esa line they have the 27 uf for the rest.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 51,809
    edited June 2013
    Yes, much better. :smile:
  • soundfreak1
    edited June 2013
    Ok order corrected. Thanks. Also have the hurricane nuts ( no spikes on them) and neutrik connectors for the connector between upper xover and lower one.mills risistors new 5 way binding posts gold slip on terminators. After that new grill cloth all around and spikes for the risors.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • drumminman
    edited June 2013
    You're gonna love 'em when you get the mods done.
  • westmassguy
    edited June 2013
    Not to beat a dead horse, but you could have used 2 x 27uf for the 55ufs. That would have put you within 2% of the original spec.
