Polk LSI Side panel: Real hardwood or veneer?
xftman
xftman Posts: 153
edited May 2013 in Speakers
I got a pair of lsi9 black from local CL today. Tested sound good and over all good except few scratches on both side wood panels and missing front covers. No scratch on black gloss panels. I am think refinish(sand down and stain) the wood panel but have to make sure they real hardwood. if not, can I replace the panels? Can I remove the panels fromthe speaker? what are my options?
Please advise!
Thanks,
Joe
MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400.
Post edited by xftman on
    F1nut Posts: 51,674
    edited May 2013
    They are wood veneer over MDF. IIRC, the side panels on the early models are fairly easy to remove, but the later models are much more difficult. Try a search here as I know some of the guys have worked on the side panels.
  • xftman
    xftman Posts: 153
    edited May 2013
    Thanks, Found all old threads. I have the old series that are gloss on both sides. I guess my options will be either replace with new hardwood or without. But since I have all my LSI series in cherry (except the center) and I have done some wood working before I most likely will replace with cherry finish.
    I will have to call Polk CS for a new set front covers.
    MAIN:
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
