Looking for new polks, sugestions?
digitalsonic
digitalsonic Posts: 12
edited May 2013 in Speakers
I want to buy new Polks and would like to hear what your experiences have been lately? This is an update to my family room HT. I'm not too worried about the price.
Post edited by digitalsonic on
  • D_M
    D_M Posts: 175
    edited May 2013
    What is your price range? How many speakers are you upgrading? What components does your current system consist of?
  • heartystatue
    heartystatue Posts: 329
    edited May 2013
    Check out the LSIM series. There are alot of reviews online. I listened to just the LSIM707 last weekend and they are very impressive.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • Bob1947
    Bob1947 Posts: 39
    edited May 2013
    I 2nd that recommendation regarding the 707's. I just picked up a pair and they are something. I also use the Monitor 60's and the Lism 9's. Both very good if the 707's are out of your budget. I have been a loyal Polk customer for the last 30+ years so have limited knowledge of what else is out there, but there are plenty. Go listen to as many as you can and resist the quick plunge. Good luck on making a decision.
    Regards, Bob
    Samsung PN51E6500 Plasma
    Marantz UD 7006 7.1 Blue Ray/CD/DVD Player
    Marantz SR 7007 HT Procesor
    Polk LSiM 705 Fronts
    Polk LSiM 706c Center
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
    Music Hall 5.1 SE TT
  • Bob1947
    Bob1947 Posts: 39
    edited May 2013
    I'm sorry I mean 705's vice 707's. My bad.
    Regards, Bob
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
  • PSOVLSK
    PSOVLSK Posts: 5,433
    edited May 2013
    Can't go wrong with the LSiM series.
    Bookshelf or floorstanders? Will you be using a sub? Answer those questions to decide between the 703 and 705/707. I own the 703 and I highly recommend them.
