Need advice for Monitor 70 speakers
ordiesep88
ordiesep88 Posts: 3
edited June 2013 in Electronics
I have a Yamaha RX-V567 avr and Polk monitor 70s series II and the speakers sound OK but I feel like they can sound better I just don't know how. It doesn't sound as clean or crisp as i'd like them to sound. Could it be the receiver? Or do these speakers sound a little muffled or muddy no matter which receiver or amp is being used? Blu rays, directv, video games all sound similar to me. Any way to improve the clarity of these speakers would be awesome even if its just a little bit. Any ideas or recommendations? Thanks!!
Post edited by ordiesep88 on
  • Bob in WI
    Bob in WI Posts: 155
    edited May 2013
    I just sold mine & they are great speakers. They have some frequencies where they were a hair laid back but never muddy or muffled. The highs were crisp & the bass punchy. I was powering them with a NAD 100wpc receiver. They do have a sweet spot so it is worth the effort to experiment with placement. I had the original Monitor 70s with 4 drivers & the tweeter. I'm assuming we're talking about the same series. Good luck. Hope this helps.
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    I also have the monitor 70s and they sound great! nothing wrong with them and they sound nice crisp and the bass is great!
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited May 2013
    Placement is key as bob suggested experiment. I briefly thought my 70's were muddy as well I moved them around a bit now they sound wonderful.
    edited May 2013
    Would help if we knew the rest of the gear, cables used, placement, if you set up the receiver properly, subwoofer ? Crossover settings ? Can't just blame the speaker for poor sound.
  • ordiesep88
    ordiesep88 Posts: 3
    edited May 2013
    this is great advice guys thank you so much!
  • pretzelfisch
    pretzelfisch Posts: 160
    edited May 2013
    Lots of people say they open up with more power from a dedicated amp. Also try your sound with the receiver set to straight or direct. It could be a eq setting. YAPO gets confused sometimes, It will also try to make all your speakers perform the same, so if you have a pair of weak speakers for a rear it will try and accommodate them.
  • ordiesep88
    ordiesep88 Posts: 3
    edited May 2013
    yeah thats what i keep hearing too. i've played with the settings and i did the best i could. i'm hoping theres something else in settings that i may have missed. i'm in the middle of moving to a new place so as soon as i setup my speakers i'm gonna dig deeper in to the settings.
  • Bob in WI
    edited June 2013
    Bi wiring seemed to help also but I did not do back to back comparisons. Seemed to add some punch to the bass but again; thats an impression, not a fact.
