monitor 30 trouble
dizzyrapper18
dizzyrapper18 Posts: 15
edited May 2013 in Troubleshooting
i have a denon 2113ci and hooked everything up but when i do the audessy calibration the right side of the m30 beeps good but the left side does it very softly and then the reciever shuts off. any ideas?
Post edited by dizzyrapper18 on
    edited May 2013
    The first thing to do is the "obvious". Switch out the two M-30s, assuming that one works and the other has the problem. If the problem follows the speaker. Then the speaker needs some attention. If the offending speaker sounds fine on the other channel, then it is the Denon that is in question.
    Once that is known, other suggestions can be offered.
    cnh
    edited May 2013
    Check your speaker connections too. If using bare wire ends, make sure no strands of wire are touching another post on either the receiver end or speaker end. Where is the mic set up at ?
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    What tony said, That is the most common problem when using bare wires... Banana plugs ftw
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2013
    With Monoprice around even the poorest of us can now afford banana plugs.
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=9436&seq=1&format=2
    edited May 2013
    In my experience Denons are not as picky about perfectly screwed down connections as Yamahas and NADs are. Yammies and NADs short out if you haven't taken a WRENCH to there speaker terminals.
    It is possible that a bare wire touching another may be a factor here. But it's also possible that that is not the problem. So check "everything" above and tell us what you found!
    cnh
