Monitor 10 Rebuild with "TL" Mod
westmassguy
This project was a lot of work, but a lot of fun as well. In addition to the Crossover rebuild and modification, the cabinet was re-worked as well. Clarity ESAs were chosen for the Hi-Pass, Mills Resistors, Dayton 5% for the Lo-Pass, and Jantzen Inductors for the "TL" modification. I like using the Daytons for the Lo-Pass shunts for several reasons. Their quality is consistant, and they're relatively small compared to the Clarity PX or SA caps some others may prefer, and in my opinion, their sound is neutral when used in the shunt position. Changes required for the "TL" Mod included changing the Resistor in series with the Tweeter, and changing the Inductor located in the shunt. The resistor wasn't a problem, however the Inductor was a bit problematic. Jantzen had the exact value I needed, 0.27mh, but the DCR was slightly less than required. To compensate, I raised the value of the 2.7 ohm Resistor in series with the Inductor, to 3.0 ohms. This kept the overal resistance value of the shunt in line with the revised schematic, and would maintain the desired voicing of the new Tweeter. In addition to the other modifications, the Polyswitch was removed, and replaced with a 0.5 ohm resistor. All Resistors were relocated to the underside of the circuit board, to allow more room. A new supplimental riser board was fabricated and installed for the Clarity ESAs. New Nylon Stand-Offs were installed, and New Cardas Binding posts were added to complete the Crossover upgrade.
Home Theater/2 Channel:
dhsspeakerservice.com/
Post edited by westmassguy on
Wow looks like a lot of work, but looks like it would be a great deal of fun! Good job on the rebuild!Receiver: Denon 1912
Speakers:
Fronts: Polk Audio Monitor 70s (x2)
Rears: Polk Audio Monitor 50 (x2)
Center: Polk Audio Monitor 70
KLH Sub GFX-550 -
The Drivers and PRs were Dynamatted, and the magnet assemblies glued. You'll note one of the drivers was replaced with a new replacement driver from Polk.
dhsspeakerservice.com/ -
Nice work WMG! What kind of glue did you use to prevent magnet shift? It looks white in the pics."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Hurricane nuts were installed for all the drivers. The cabinet was internally re-sealed with clear acrylic, and the center brace was also re-glued since there were gaps in the original hot glue Polk used. New Quartered Walnut Veneer was installed, stained and finished. The raw particle board on the back edge was sanded, sealed with lacquer, then two coats of satin black enamel applied.
Final assembly included reposistioning and tacking in-place the Dacron Batting.
After all drivers were installed, air leakage tests were done, then sweep test tones to check for resonance and rattles, and lastly, New, Acoustically Transparent, Architectural Grill Cloth was intalled. The sound from these puppies is truely amazing.
Thanks, was a lot of funcustopper30 wrote: »Wow looks like a lot of work, but looks like it would be a great deal of fun! Good job on the rebuild!Home Theater/2 Channel:
I used the same clear acrylic adhesive, Loctite. It goes on white, but dries clear.drumminman wrote: »Nice work WMG! What kind of glue did you use to prevent magnet shift? It looks white in the pics.Home Theater/2 Channel:
Very nice work and dedication!
Wow, nice work on those. I bet they sound sweet.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Fantastic job!!!
ThanksConradicles wrote: »Fantastic job!!!Home Theater/2 Channel:
Very nice!Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Very nice ! How do they sound compared to stock ?
Thanks for sharing.Speakers: SDA-1C (most all the goodies)
Thanksjeremymarcinko wrote: »Very nice!Home Theater/2 Channel:
It's like night and day. Everything that's good about the 10s was retained and improved, and things that weren't so good, are now outstanding. The new Tweeters and crossover upgrades made the top end sing, and the Hurricane Nuts, Machine Screws, and Dynamatting, tightened up the bass like you can't believe.Very nice ! How do they sound compared to stock ?
Thanks for sharing.Home Theater/2 Channel:
Damn those look nice! Wish mine looked like that. So how much did it run to do this mod?--Gary--
Thanks halo. PM me if you'd like specificsDamn those look nice! Wish mine looked like that. So how much did it run to do this mod?Home Theater/2 Channel:
Very nice work. Pride of accomplishment is an awesome feeling and you sure show it with your thread/posts. Congratulations
I have to see where Feeding Hills Mass. is in relation to Charlestown RI -
Thanks NJPOLKER. I'm 10 minutes from Six Flags New EnglandVery nice work. Pride of accomplishment is an awesome feeling and you sure show it with your thread/posts. Congratulations
I have to see where Feeding Hills Mass. is in relation to Charlestown RIHome Theater/2 Channel:
Beautiful job, congratulations!
Thanks KenKenneth Swauger wrote: »Beautiful job, congratulations!Home Theater/2 Channel:
Everything looks very professional and well done. Now they are much better than they ever were way past new.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Thanks PolkieManEverything looks very professional and well done. Now they are much better than they ever were way past new.Home Theater/2 Channel:
WOW, Dave! Those look fantastic, inside and out! Very nice work! Looks like you really did sweat the details. I'm guessing those are gonna be some long-term keepers. :cool:
Few questions for you:
Any sound quality difference with that one new driver?
What size H-nuts and Machine Screws (length too) did you use? Where did you get them? Any problems with the flange of the H-nut interfering with the driver baskets inside the cabinets? Did you use them on the binding post cup and tweeters also?
How did you fasten your new grille cloth to the frames? Any pointers/pics on how to make good sharp corners? Did you notice a sonic difference with this upgrade?
Did you consider re-doing the internal wiring? Any plans for that in the future?
What are you driving them with, power-wise? Are you using them in a 2-channel setup? HT?
You mention sweep test tones to check for resonance and rattles. Can you elaborate on this process a little?
Thanks for any info you can share. I'm a big, big fan of the Monitor 10 sound and have a pair that I've had since they were new and will likely be keeping them for good. :biggrin:
Lastly, I don't think you mentioned it above - and please correct me if I'm wrong - but it should probably be noted that to do the "TL" mod for these speakers, people will be using the RDO-198 tweeters and not the RDO-194 tweeters. -
Thanks. Too many questions for this thread. I'd be happy to answer any question directly via PM or email.teekay0007 wrote: »WOW, Dave! Those look fantastic, inside and out! Very nice work! Looks like you really did sweat the details.
The RDO-198-1s are part of the TL Mod, that's pretty common knowledge on these forums.Home Theater/2 Channel:
Oh don't thank me:cheesygrin: it's people like you that have really inspired me on this hobby.
Especially the real wood veneer that looks so much better.westmassguy wrote: »Thanks PolkieManPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
I've been veneering on and off since I was 15 or 16. It's not as difficult as you would think.Oh don't thank me:cheesygrin: it's people like you that have really inspired me on this hobby.
Especially the real wood veneer that looks so much better.Home Theater/2 Channel:
