Krell KSA-250
  • FTGV
    FTGV Posts: 3,650
    edited May 2013
    SCompRacer wrote: »
    Next time I'm over there I'm gonna have to pop the cover on that Classe to make sure it's a Classe inside.:lol:
    Yeah,we might begin to see a new trend where by folks are velcroing GFA555 face plates to their Emo's for photo's posted on CP.
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2013
    Yeah I failed English class. Thank goodness for spell check! Back to my Emotiva!
    Carl
    SCompRacer Posts: 9,112
    edited May 2013
    schwarcw wrote: »
    I need help with the classes you didn't fail.....the thermal stuff. I'm thinking of water cooling the KSA!:eek::twisted::lol: More push lock fittings in the wall, small car radiator and water pump in the basement. I need help with friction loss from wall shear stress caused by turbulent flow in walled tubing.
    I should have the room all set up this weekend. I'll use the more powerful Sanders amp to run the bass modules. (Now I need a another level on the amp stand!:lol:) Also made some decoupling stands for the speakers.
    heiney9 Posts: 25,440
    edited May 2013
    I am officially offended. You guys were in Ohio and didn't come over. :frown:
    I'm a decent host. Just ask Doug & Brock
    He was, fantastic. And he owns a GTI too. Not bad at all.
    edited June 2013
    I look forward to hearing how this sounds compared to the sanders
    I had my get together June 22. I didn’t want to influence anyone with my impressions prior to them hearing it. Some folks were running late so I only had 2 or 3 folks here for the amp compare and they shared my impressions after hearing both amps.
    There is around a 100 WPC at 4 Ohm advantage to the Sanders and more important a gain difference between the two that created less than ideal circumstances for comparison. With the Krell, panels were a few dB softer and much more laid back compared to the bass amp. When I reduced the bass/mid bass active settings I could get a better balance but lows lacked in dynamics. To make it work I would have to boost the treble relative to the bass. If it were the other way, I could attenuate a hot panel amp down.
    In an attempt to make it work prior to the meet, I tried a Behringer DCX2496 UltraDrive Pro digital active crossover. With that I could really get aggressive with slope, 48dB / octave compared to my 24dB / octave analog and also lower the xover point. I could also boost the panel amp independent of the bass amp. That worked great to balance the amps but unfortunately the Behringer introduced a low level hum from the panels that I could not eliminate. I had a dead quiet system before that was really annoying.
    I would also get distortion at above 90dB listening levels with the Behringer and I was no where close to clipping on the input or output based on the UltraDrive’s front panel LED’s. Now I don’t listen at those levels all the time but will not be denied it if I choose to and without any distortion.
    So in my case with the InnerSound MK II active bass amp, the Sanders amp works out better than the Krell on the panels. I don’t even want to think of having two KSA-250’s in the same room but it would be interesting to try one connected to the active low pass outputs.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2013
    Well it seems like I need to start putting one of sanders on the horizon as the claims about his amps being good for panels are founded
    EndersShadow Posts: 17,705
    edited June 2013
    SCompRacer wrote: »
    Rich, you do that and you wont need to ever use your heater in winter. Heck just put your water heater on it and you wont need to heat your water to keep it hot either...
    nooshinjohn Posts: 25,929
    edited June 2013
    You need to put a pair of my tube amps on your list as well.
    edited June 2013
    Will you take a kidney as payment John? I got two but only need one :biggrin:......
    And you wanna do a 9 channel set of amps for me for my HT in the house when we buy it :mrgreen:
    edited June 2013
    I've tried quite a few amps on the panels and the InnerSound ESL MK II and Sanders amps have been the best so far. The difference between them are the Sanders uses larger toroidals with improved transistors. The Sanders has worked well with some conventional speakers too, some not. Roger has a 30 day free trial. His amp was one of the few audio things I ever bought new. He took some gear in on trade; it was priced at $3K then.
    Crazy as it sounds, I had a moment where I thought of water cooling the Krell if I kept it. Large aluminum water blocks bolted to the sides. A little math for water flow, a radiator with cooling fan and water pump in basement, plumbing through wall.:eek:
    edited June 2013
    Are you selling the Krell?
    edited June 2013
    SCompRacer wrote: »
    Not Crazy, being a PC guy watercooling is something I am intimately familiar with :biggrin:. You coulda then taken that hot water and used it for "radiant" heat in the rest of your house on the floors.....
    That would be crazy right there :smile:
    edited June 2013
    About 10 years ago I was heavily involved in on line gaming, over-volting, overclocking and water cooling PC's.
    That is on hold right now; it is a kick **** amp and I may keep it. I also have some interest locally but need to get it over to the guys house so he can try it. If it were for sale and needed to be shipped, I'd have to build a wood box for it and attach it to a skid for freight shipping. I have the original box but the internal packing shell was missing.
    IIRC Ed Savinon has another stereo KSA-250 for sale.
  • schwarcw
    edited June 2013
    I love that KSA-250! A nice preamp and the Krell will knock the wind out of your chest. Talk about dynamics!
    Carl
