Denon 3910 doing the funky
Mr. Sharpe
Mr. Sharpe Posts: 1,359
edited May 2013 in Electronics
Here's what it's doing. I turn it on and the display reads "Dvd 3910" then turns off. The dimmer button does not do anything on remote, Batteries are fine because you can open and close the tray with it. whenever I push a button the display will come on for a second and turn back off. I've tried turning the batteries around and doesn't help.
Here's the second thing, I am using a Firefold HDMI cable, new 42" LG, the purple denon screen does not come up, in fact all it says is no signal as if it weren't plugged in at all. I do have the TV on the right input and have actually tried both HDMI inputs just for kicks and nothing. And have tried switching the cable in both inputs, nothing. it will not work with Component cables or composite cables either. I have unplugged and turned off, turned off the main power switch and reunplugged again and again and still nothing.
Please help, it started with not reading Cd's then running very loud (still does up until quitting) to this. I would replace the laser anyway so it will do Cd's again but then I have a 2800 that does that fine. Do I need a new laser? Help please.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Post edited by Mr. Sharpe on
  • stubby
    stubby Posts: 723
    edited May 2013
    Denons are notorious for going through lasers but this sounds like a different problem. Tried any of the Denon forums?
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
    F1nut Posts: 51,698
    edited May 2013
    Running loud would indicate a spindle motor problem.
  • Mr. Sharpe
    edited May 2013
    stubby wrote: »
    I don't think to do that. I should though huh?:)
    I agree, it's the same problem I told you about last time. I put oil on it, still made noise, put more still no luck. You can get the whole motor and laser assembly for $20 online though.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 51,698
    edited May 2013
    Can you hear that the noise is coming from the spindle motor?
  • Mr. Sharpe
    edited May 2013
    Idk F1, what else could it be besides that?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 51,698
    edited May 2013
    Well I agree it probably is the motor, but it could be something rubbing.
    nooshinjohn Posts: 25,890
    edited May 2013
    I don't think rubbing would take the display down. The noise however sounds like a motor that has gone bad, and possibly other parts as well. Personally, I think it's time to move on to something else.
    F1nut Posts: 51,698
    edited May 2013
    If the spindle motor or transport motor are binding up because they are bad or there is something else causing one of them to bind up it could take out the logic board.
    pitdogg2 Posts: 26,959
    edited May 2013
    http://www.thuntek.net/~bk11/home.htm
    Steven Sank @ talking Dog Transducer. Steve really knows his stuff has helped me over the net to find problems on my Sony Es Cd player and locate problems on Denon stuff. Beware that he is/was a authorized Denon repair shop and just rails on Denon for the lasers they decided to used. The Denon lasers have a high failure rate and for 3$ more Denon could of used laser's that have a 1% failure rate compared to their much higher rate. As he put it to me "It's not if it's when it will fail and it will fail"...his comments. He'll get you right
    Ivan
  • Mr. Sharpe
    edited May 2013
    Well I have considered other players and have been scared this one was going to bite the dust eventually:(
    Would Marantz be good? Highly thought of right? their older DVD players that do 1080p upconverting is all I need. there are several on the Bay but prefer a player of girth like the 3910.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • skrol
    skrol Posts: 3,437
    edited May 2013
    Have you tried disconnecting enerything except the power and see if it will read a disc?
    I am wondering if it isn't liking something with your new setup (ie hdmi cable or tv).
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • DaveHo
    DaveHo Posts: 3,583
    edited May 2013
    Does the 3910 have the "Pure" function that turns off the front panel display & video output? You sure that's not engaged? Just a shot in the dark.
  • skrol
    skrol Posts: 3,437
    edited May 2013
    The 3910 does have such a function (Pure Direct) which can disable the display and the video output to minimize noise for audio only.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited May 2013
    DaveHo wrote: »
    VERY GOOD CALL!!!!! I've never used it but had the same problem with my 3805 badda bing badda boom took me 3hrs to figure that out....I felt soooo silly afterwards...
  • Mr. Sharpe
    edited May 2013
    skrol wrote: »
    I've used the HDMI for about 3 months. I did try unplugging the HDMI, but I stick a DVD in and it reads it and plays it, just no picture no sound no display. I"ll have to try pushing the pure button.
    DaveHo wrote: »
    YOU CAN TURN THE PICTURE OFF?? HOW IN THE WORLD YOU DO THAT?? is it the pure direct button? I'm sure it's off, my son may have ingaged it but I pushed the pure direct button and it says off.
    skrol wrote: »
    I didn't know it turned the picture off. cool. will have to stick it in there.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited May 2013
    Man I was so totally going to ask what player you went to because I knew you had two of these! Yeah I wish I could get an Oppo but like I said earlier, the one I would want is the 95, big one:)
    anyways, so I pushed the pure direct button on the player, display came back and picture as well lol just a simple thing I blew up hahaha, ignorance really. because I never knew you could turn the video off. I know on a Pioneer Elite I have just has a "video off" button. of course Denon has to be complicated. thanks a bunch fellas. If this thing ever does go out it will be an Oppo though. heard too many good things about them.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • DaveHo
    DaveHo Posts: 3,583
    edited May 2013
    Awesome! I have the Denon 1713 BD universal player. About once a week my wife calls me at work trying to figure out why MY stupid equipment doesn't work. This is usually the problem.
  • DaveHo
    DaveHo Posts: 3,583
    edited May 2013
    Of course it's always my fault for not putting it back to "normal".
  • Mr. Sharpe
    edited May 2013
    Lol of course, goodness knows she didn't try all the buttons on the remote and player trying to make it work hahaha!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
