5.1 With Vintage Polks, Anyone?
All Vintage for me except a little help from the MicroPro sub.HT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect. -
Same as nooshinjohn except monitor 70 for rear surroundsnooshinjohn wrote: »SDA-SRS 2.3TL's for my mains with a CSiA6 for a center and LSi-15's for surrounds.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Setting up a ht sys. around two pair of 5jr+'s..Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Monitor 7C's with a CS400 center works well for me. I need to pick up some 4's for the surrounds though and upgrade the sub, just not sure what to get there, maybe the 505.
In the bedroom I have a 3.0 system with Monitor 7's with Peerless and a CS175 center. Sounds pretty good and I use it more for music than the home theater so I use it in stereo then and just use the center for TV.
