Powering my RTI A9
Poolgod69
Poolgod69 Posts: 184
edited May 2013 in Electronics
I am starting to look at a preamp and amp to power my RTi A9's. I recall reading that these speakers can be on the bright side which I do tend to agree with. I also, recall someone talking about using a warm amp vs. a bight amp. I am unsure how to determine a warm/bright amp and frankly never even new of such a thing until I joined here a few days ago.
I guess I will get the answer out of the way now since someone will ask. I feel comfortable averaging 600 for both. I would prefer to buy new but would go used if the dealer/seller was reputable. I definitely could save for a few months if needed to up the cash.
Please do not suggest a preamp/amp based on the price alone listed above. I am also learning and I am open to suggestions. But let's be realistic also...:smile:
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
Post edited by Poolgod69 on
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2013
    I went the pro-audio route and picked up a Yahama PS2500 and Focusrite interface (fed by my computer via USB). This cost me a little north of $600 but is well worth it. They are both bullet proof pieces.
    As a matter of fact I just saw a pair of PSB Stratus Silvers near me for less than three Benjamins and I like knowing that I have an amp that will drive it no problem. I think a warm sounding amp would be more tube derived. I would describe mine as neutral and uncolored. Just out of the way and makes the LSi 9's sing.
    I picked everything up at Guitar Center with the safety of being able to return it all. They let me demo there to my hearts content and really had a good amount of know how to share.
    Also look at the Crown XLS DriveCore. It seems no matter where you look people are REALLY impressed with it. AH/AVS/HTS/Parts Express Tech Talk/HomeTheaterGuide/BlueRay Forums.
    F1nut Posts: 52,000
    edited May 2013
    A few suggestions in no order.....
    Wyred 4 Sound amp with a tube pre amp, maybe a Jolida or CJ-PV10
    Parasound 2250 or 3500 amp with a Eastern Electric Minimax tube pre amp.
    BAT VK-200 amp with a BAT VK3 tube pre amp. This would be my choice on a limited budget.
  • deronb1
    deronb1 Posts: 5,021
    edited May 2013
    +1 on tube gear with the RTiA series. Also, other warm sounding solid state gear would be B&K, Carver or maybe some older Rotel stuff. I had a Kenwood amp powering my RTi12s. It was pleanty of power, but just not a good fit with those speakers.
  • snake1
    snake1 Posts: 567
    edited May 2013
    Parasound amps def do well with the rti line! There is a parasound 3500 for sale right now on audiogon (no affiliation). Plenty of amps to drive your A9s!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • Poolgod69
    edited May 2013
    I appreciate the information. I am looking forward to searching for the right amp.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • Thorton
    Thorton Posts: 1,324
    edited May 2013
    +1. I've used both Wyred 4 Sound and the Parasound 2250 amps with the RTIA9's with great results. No preamp yet, I'm still using a AVR. But for my ears, I like the pairing.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Poolgod69
    edited May 2013
    Learning again.............. So excuse the question.
    How are you using the straight amp?
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    pitdogg2 Posts: 27,318
    edited May 2013
    Poolgod69 wrote: »
    some mid to uppermid and all high end receivers have pre-outs to use external amplification which turns your receiver into a pre amp function.
  • Poolgod69
    edited May 2013
    OK... I understand that about the pre amps.... However, the post indicated:
    After, looking at the signature line he listed he was using the Denon AVR-3805 which I did not see was a pre amped model.
    Thanx for the info!!
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited May 2013
    Fwiw I really enjoy my Parasound 2003. 220W x3 works great for home theater and music. There's one for sale on EBay right now. ;)
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Poolgod69
    edited May 2013
    Thanx for the tip. I looked at it and I do like it!!
    3 channel and 220 wpc@8 ohms sounds nice to me!!
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • Thorton
    edited May 2013
    Poolgod69 wrote: »
    I've had the AVR for a long time which has preouts. I upgraded to the RTIA9's and then purchased the amps hooked directly up to the preouts on the AVR. I use my set-up for 2 channel music and 5.1 movies. I like the pairing of W4S or Parasound with the A9's. My next upgrade with probably be a dedicated pre/pro or preamp. But after a few recent additions this will be a little while. In my case, both amps were a significant improvement from just using the amplification in the AVR.
    Since you are on a budget, I would go used. Do some searches to learn up on amps, brands, models here. Once you get to 100 posts you can view the "For Sale Classifieds" where amps and pre's come up often. Otherwise Audiogon, Ebay and craigslist. If you find something you like or have questions, post it here. There are many knowledgeable experienced people to help out. Good luck.
    DAC: Bricasti M1SE
  • Poolgod69
    edited May 2013
    I appreciate the additional explanation. I will find something eventually that I will be satisfied with but will ask many questions along the way.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
  • soundboy
    soundboy Posts: 7
    edited May 2013
    How will RTIA9 works with monoblock Xindak Xa-8800mne in the case?
    Have one pair of Xindak amps.
    Have "looking" for RTIA9 speakers..
    Car : Alpine W910R/H701, Polk Audio SR6500 coaxes, 2x Pioneer ODR 10",4x Sony XES-M50
    Home:
    Samsung LED 55"
    Canal Digital - HD-PVR
    Oppo BDP-105EU codefree
    Yamaha RX-V659 (Replace to as new 2013 model, Yamaha RX-A2020/RX-A3020? Or..?)
    Xindak XA-8800MNE
    Polk Audio LS50 (Replace to as new 2013 model, RTIA9, CM9? Or..?)
