Polk Monitor 7A with peerless resistor value...
Mystery
Mystery Posts: 2,546
edited May 2013 in Vintage Speakers
Finally opened up my 7A's and to my surprise, it has 4.7 Ohm resistor along with a 2.7 Ohm resistor.
None of the schematics mention that extra resistor and also some other thread have 4.5 Ohm instead of 4.7.
So, should I replace it with 4.7 Ohm or 4.5 is okay?
Or, do I even bother about replacing resistor?
They look okay and I'm planning on replacing capacitors.
Also, is that black 34uF capacitor electrolytic there?
It doesn't look like normal electrolytic with aluminum foil.
Pic below:
Post edited by Mystery on
  • Mystery
    edited May 2013
    I ordered correct values.
    Looks like this version is not in the schematics list that's the reason for this thread as the schematics only mention 2 ohm or 2.7 ohms but none mention additional 4.7 ohms resistor.
    Here is a draft:
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited May 2013
    I'm thinking you should replace the caps and resistors with identical values to what's on the board.
    Now the trick will be making the decision on the caps and resistors. Some say this and some say that but whatever you decide will be a pleasant upgrade to the stock caps and resistors.
    Use the search function for we have a lot of info on the upgrade process.
    Good luck.
  • Easy Runnin
    Easy Runnin Posts: 501
    edited May 2013
    Did you check the other speaker? I have a 4.5 in one and a 4.7 in the other. Go figure.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • Mystery
    edited May 2013
    Yes, both have exact same parts and values even with different cabinets.
    Just finished my 1st ever crossover upgrade on them and sound excellent.
    One of them was horribly muddy before.
  • StantonZ
    StantonZ Posts: 452
    edited May 2013
    Why no capacitor in parallel with the 4.7 Ohm resistor? Why is this XO so different than the other Monitor 7's & 10's (I'm getting ready to rebuild my 10B's). Did they really change that much from the A's to the B's??
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
