XPR-1 Review for EMO fans
Jhayman
Jhayman Posts: 1,548
edited May 2013 in Electronics
Much awaited reviews coming in..
Excellent review:cheesygrin:
http://www.audioholics.com/reviews/amplifiers/emotiva-xpr1-amplifier
Post edited by Jhayman on
«1345
  • erniejade
    erniejade Posts: 6,321
    edited May 2013
    Requires a 20 amp line! Looks hefty!
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Not really.. only if you go and crank the volume and trip a breaker. Lots have stated one can just use a 20 to 15 amp convertor for it or just swap in a 20 amp outlet on the 15 amp line.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    nooshinjohn Posts: 26,000
    edited May 2013
    Wow, a review on Audioholics is a must read!:rolleyes:
    I would take a peak at it but life is way to short...
  • Jhayman
    edited May 2013
    Why was their Review of the Pass Labs X350.5 not good enough..:rolleyes:
    They explain their testing procedures quite thoroughly..
  • Habanero Monk
    Habanero Monk Posts: 715
    edited May 2013
    AH has some of the most rigorous and vetted testing around. They have Josh Ricci doing their sub reviews. The articles on Amplifier slew rate and gain staging are must reads. I read them for the editorial content primarily. AVS is also doing a great job by bringing Scott Wilkerson on board. Guy does some great interviews.
    heiney9 Posts: 25,497
    edited May 2013
    Audioholics is a joke. AVS is as well. The testing isn't real world it's lab specs. Last time I checked we don't listen to our gear in the lab. It's ridiculous, IMO. And I don't care if it's Emo, Pass, Krell or McIntosh. I don't use their writings as a resource.
  • Habanero Monk
    edited May 2013
    heiney9 wrote: »
    It's certainly designed there. And when it's voiced (in the case of speakers) it certainly isn't voiced to your or my room either. I also like PETT and HTGuide for what they seem to provide the enthusiasts.
    edited May 2013
    They are equivalent to Consumer Reports, not for enthusiasts. When the very first line of a review on an amplifier starts how with "how green is it?", it has nothing to do with being an enthusiast.
  • Habanero Monk
    edited May 2013
    heiney9 wrote: »
    ?? I just read the first paragraph titled "Introduction" and can't find "how green is it?" I think it's an interesting question but may not be a concern to the audience that would purchase it. I could imaging lower idle current may have an affect on component lifespan due to lack of heat(?)
    What is it that is equivalent to Consumer Reports? Are you talking about the analytics? Don't see the problem with that.
    F1nut Posts: 51,998
    edited May 2013
    eclypse wrote: »
    That's incorrect. If you were to run any amp requiring a 20 amp service off a 15 amp line, then switched to a 20 amp line you would hear the improvement at any volume level.
    See above.
    Completely against electrical code.
    F1nut Posts: 51,998
    edited May 2013
    heiney9 wrote: »
    Correct and lab specs cannot tell you how a piece of gear sounds.
  • Habanero Monk
    edited May 2013
    Ears on. Caveat Emptor and all that. Be interesting to see some reviews in the wild.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    There was a guy saying he ran 3 of those XPR amps off a 15amp circuit and all was fine at loud volumes without tripping a breaker. Said he didn't want to try louder as for fear of breaking the windows haha.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • Jhayman
    edited May 2013
    Eclypse..F1nut is correct in his post answers..
    Even the review says you can power in on a 15amp service but to fully unleash this beast you need a 20amp service..
    edited May 2013
    A look at the list of "recommended" brands has me scratching my head. Polk Audio not mentioned but Bang & Olafson for speakers???
    No thanks.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2013
    It would seem to me that a review which starts with Although it lacks the snob appeal of some of the expensive and prestigious brands is either pushing an agenda, or trying to rationalize some unstated shortcomings. What is expensive in this case? $2000? $20,000?
    That said I am sure it is a fine $1500 amp. However, I wonder why the Bryston 28B-SST2 does not require a 20 amp line, and costs $9600. I guess the 20 year warranty and snob appeal add up.
    http://www.audioadvisor.com/prodinfo.asp?number=BY28BSST2
  • headrott
    headrott Posts: 5,496
    edited May 2013
    eclypse wrote: »
    Loud is one thing. Having audio produced with clarity and detail is another.
    edited May 2013
    eclypse wrote: »
    That right there should have told ya something. Also, if you don't like fires, you need to have the proper rated wire in the wall between a breaker box and outlet. You don't just drop in a 20a outlet and call it a day. Anyone who does that I would seriously consider their review of anything audio dubious at best.
    I'm sure it's a fine amp, like their others but I have yet to get an ear on anything they make that puts SQ as the number one priority over price. Who knows, maybe it will be this one......:cheesygrin:
    Toolfan66 Posts: 18,184
    edited May 2013
    headrott wrote: »
    Yeah, but unfortunately some don't understand that, if its loud, and can go boom, that's clarity and deep detailed bass:rolleyes:
    edited May 2013
    Great. I never have and never will use AH or AVS reviews regardless of brand reviewed. Also you are incorrect in your assumption that lower idle current and lower heat levels mean longer life. There are many pure class A amps that have the same or longer lifespan and by the nature of the design run hot to very hot. If something is designed incorrectly or too many corners are cut, heat might become an issue in premature life. If done properly, it's never an issue beyond making sure you have proper ventilation which usually means no cabinet confinement or component stacking.
    I am not picking on this post because of EMO, but because I personally think AH lacks any sort of credibility when it comes to knowing what sounds good vs. great vs. exceptional. That is IMO and if one feels differently then that's your own opinion.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2013
    Seems like no one will ever be happy when it comes to audio reviews of any kind, not just Audioholics. Of course reviews of amps don't tell you how they sound... but they can give you objective measurements so you can compare them to the measurements of other amps. Does that tell you how they'll sound in your room or with your speakers? Of course not... but then, no one possibly could. It just gives you a basis for comparison to other gear that they've tested, and there is value to that.
    As far as the XPR-1 goes, I will never have speakers that require that kind of power... so that amp's not made for me. But it's good that they're making an amp for that market, if a market even exists for it (and I'm not sure one does outside of people who just want to say they have a 1kw amp).
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    edited May 2013
    Measurements mean nothing, NOTHING. They don't tell you how something sounds nor how they will interact with other gear in a system.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Measurements compared across components don't really mean anything or relate how each will sound against each other. Just like horsepower, torque, 0-60 times, braking distance across automobiles won't give you a good indication of how the car rides, handles or responds compared to each other. Sure if the measurements are horrid then that's a good indicator to lower your expectations.
    It's good to know if an amp can or cannot drive a 4 ohm load, but you can't really tell by looking at wattage specs. Someone needs to test for that specifically, so while I don't believe measurements have much use they can be indicators in some narrow instances to help make a decision. But they will never really tell you how something sounds.
    P.s. Look at these specs, if one strictly made decisions based on specs, this wouldn't even get a 2nd look. It's among the best amplifiers I've heard for reproducing audio and I have yet to run out of juice.
    Gain 20 dB balanced, 26 dB single ended
    Freq. Response - 0.5 dB @ 2 Hz, -1.5 dB @ 100 KHz
    Power Output 30 watts/ch @ 8 ohms, 40 watts @ 4 ohms
    Maximum Output 25 volts, 5 amps
    Distortion (1KHz) 0.2% @ 30 watts, 8 ohms
    Input Impedance 47 Kohm single-ended, 52 Kohm differential
    Damping factor 100
    Crosstalk > -80 dB 20-20 KHz
    Balanced Input Rejection -50 dB typical CMRR
    Output Noise < 500 uV unweighted
    Random noise floor 5 uV typical
    DC offset < 100 mv
    Power Consumption 200 watts
    Temperature 25 degrees C. above ambient
    Dimensions 17 " W x 15.5" D x 5.5" H
    Shipping Weight 45 lb.
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Wow! EMOtiva posts sure stir up EMOtion!
    Lets face it....there ARE snob esoteric brands in audio just like any other industry. There is nothing wrong with this!!! On the flip side, there are quality products made in China that bring a certain level of performance to the masses. There is nothing wrong with this either.
    But at what point or cost does it take to move from Mid-fi to Hi-Fi? If a $1500 AVR is the lower to middle what does it take to move up to the "HIGH END" audiophile level? A $5000+ amp to start?
    I say its all about the music...enjoy it! and power to the people...rather it be Emo or Bryston ! Its great to have choices in every price segment. :wink:
    edited May 2013
    WLDock wrote: »
    As long as it isn't a snob esoteric brand :rolleyes:. Nice inflammatory opening and then soft back peddle. Can you say hypocrite?
  • Habanero Monk
    edited May 2013
    heiney9 wrote: »
    Did you notice the (?). I wasn't making any assumption. I don't know if it's idle current draw is simply due to design and a by-product or intentionally sought after goal. All I know either way is if you are purchasing $1500 or $15,000 monoblocks you most likely aren't concerned about your electric bill.
  • Loud &amp; Clear
    Loud &amp; Clear Posts: 1,538
    edited May 2013
    Looks like they knocked it out of the park again. After listening to the UPA-200 ($349!, new), I have a lot of respect for the quality for dollar they are capable of. Just a tremendous success story for an American company to deliver these kinds of goods for those prices. Just crushing the overpriced competition. Love it.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • kuntasensei
    edited May 2013
    heiney9 wrote: »
    So would you prefer that there were no reviews from the enthusiast press? I think everyone who reads these reviews understands that they aren't going to tell you how something sounds in your room, with your gear. I see the measurements more as a confirmation that the amp performs as the company's specs claim, and can often show weaknesses that the amp design may have (such as not being able to handle 4ohm loads, etc.).
    It's much the same in enthusiast reviews of anything, really. Someone could tell me that the Blu-ray of a movie has the sharpest 1080p video and best-sounding 7.1 lossless audio... but I may still hate that movie. The question is whether the product itself is up to par. Also, the enthusiast press tends to be people who are as into this hobby as you, with some of the same biases... Whether you trust individual reviewers is up to you, because that's typically about their pedigree. For instance, I'm not familiar with Gene DellaSalla, so anything I read from him, I focus mostly on the numbers and not how he thinks it sounds. But a review from someone like John E. Johnson, Jr. over at Secrets, I tend to give a little more weight to his opinion of the amp's character, because I'm familiar with his experience with many brands and his knowledge.
    Speaking of which, he just reviewed the XPR-1 as well:
    http://www.hometheaterhifi.com/power-amplifiers/power-amplifiers-reviews/emotiva-xpr-1-monoblock-power-amplifier.html
    Equipment list:
    Emotiva XPA-3 amp
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    heiney9 wrote: »
    As long as it isn't a snob esoteric brand :rolleyes:. Nice inflammatory opening and then soft back peddle. Can you say hypocrite?H9
    Yes! HYPOCRITE!:cheesygrin:
    Well designed, High quality innovative products are just that to some....maybe I should have left out "snob" given this is a general audio forum? Most are enthusiast. Maybe I'm off base, don't know...you tell me?
    The truth is many that venture into quality better performing products do so for that very reason. This same person that has a rack of Krell amps would not have a problem picking up a couple of the Emo XPR-1 amps an comparing them to his collection ...just because he is interested in what performance both products are bringing to the table. How many think this will ever happen? What's the point......correct?
    However, look at this post....not only is the brand getting picked apart, also the reviewing web sites, etc. are getting picked apart.
    We all understand why a hand made in CAN Bryston amp with a 20 yr warranty is priced as such....because they want to appeal to a higher end segment and they won't sell as many units at their given price.
    In contrast, some of the super high priced audio items (Some absurd priced IC's come to mind) are solely priced for the $250K+ salary a year crowd thet get off on the snob effect of owning such expensive items. I get it! However, a quality and performance minded consumer can pick through the hype.
    Make no mistake, I get the need to have an $8000 Bryston 5 ch available and a $900 Emotiva 5 ch available in the marketplace. I GET IT! Do you?
    edited May 2013
    Most of you people posting h here are extremely contradictory in
