Wyred 4 Sound DAC-2 Addition
Thorton
Well, I'm a little late to the game but I picked up a nicely used W4S DAC-2. I chose this DAC based on the reviews and all the write-ups from Polk members. Also, I decided not to purchase an entry level DAC ($200-400) hoping for a significant improvement over my Sonos player. I could not be more happy with the purchase. It was very easy to do A/B comparisons against the Sonos via input selection with level adjustment. Immediately, I could identify the DAC-2 being very detailed and dynamic over the Sonos. The bass is very tight and fast. The highs and mids are smooth, cleaner with more detail. I would say this DAC just sounded more musical and this was noticed with every song that I've played so far. I use to enjoy the quality coming from the Sonos. But after listening to this DAC for an extended period and then returning to the Sonos alone, I could not live without this DAC in my set-up. It will be around for a long time. This is my first external dedicated DAC so I have not compared it to anything else but I would say that this has been one of the best improvements (so far) that I've made to my system in terms of SQ.
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
DAC: Bricasti M1SE
Post edited by Thorton on
Thanks...that's the one remaining DAC in my price range that I'd like to audition.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Don't you just love new equipment that upgrades your system?Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Yep. When you hook up something and it immediately puts a smile on your face is an awesome feeling.
I forgot in the original post. Thanks to all Polk members on feedback and reviews on this unit. It made my decision and satisfaction that much easier._____________________________________________________________________________________________
DAC: Bricasti M1SE
Room Treatments: GIK Acoustics -
Congrats man, sweet dac no doubt.
comparing the 2 though is apples and oranges. A 1500 dac better sound better than the cheap dac in a 350 buck music streamer. That's why we always recommend a separate dac for music streamers.....at least the cheaper ones anyway. Their ok for a casual listening on their own but a separate dac elevates them to a good cdp status.
Again, congrats man, you made a wise choice.:biggrin:HT SYSTEM-
lsi 9's -
As it burns in, it will sound even better!Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
