I love my neighbors!
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2013
    While I love 100+ db music, I have insulated my house and have double pane windows to keep the music in, and outside noise out. The police would have delivered my request list. :biggrin:
    F1nut Posts: 52,005
    edited April 2013
    SDA1C wrote: »
    With the same disc as before....116.7bd. "A" weight, Max, Fast, High and dbC, -30 db, SRS 2.3 and subs only.
    Yes, that number is more inline with the given gear. One question, did you mean C weighted because that's what I meant.
    F1nut Posts: 52,005
    edited April 2013
    Sunfire Signature amps are good for 425wpc x 5 channels. This would become 850wpc into a 4ohm load.
    His speakers are 6 ohm.
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2013
    Yes, I meant C on the 116.7 reading and A on the 123.5. Is biamping going to really do much? I understand these amps will take from unused channels if its available.
    Too much **** to list....
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2013
    BlueFox wrote: »
    I have a feeling it will come one day LOL. I do not play that loud for very long. In fact this is the first time I have done more than a song or two at that volume. I played Megadeth hits album. 17 songs! LOL. It is the longest I have ever done that. Mostly it is just a tuning or play day that sees a song or two at high volume.
    gudnoyez Posts: 8,174
    edited April 2013
    Yep Megadeth it is for me when pissing off the rappers down the street Rust In Peace, or Peace Sells, or on the lighter side Count Down. A little Dave Mustaine and the boys does it every time. At those levels your talking about, couldn't imagine
    F1nut Posts: 52,005
    edited April 2013
    SDA1C wrote: »
    Since you've got the amp, might as well try it. That said, true bi-amping is a completely different animal.
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2013
    The true bi amping being separate signals from the pre I assume rather than the same signal filtered at the crossover? I have done some car audio installs and figure this is what you mean but in that case true biamping would be amped after the crossover correct?
