Emo bi-amp question for LSiMs
Man pitdogg2, you killed my thread! lol Kidding! I don't mind.
I'm a info junkie. Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
I'd call it something else. Anyway, you seriously don't know what you are missing. Still have the original crossover parts too? If so, I'll do the labor for free, you pay for the rest. If you're not thrilled with the improvement, I'll reimburse you for the parts.
That's one hell of an offer! Shipping could make it costly._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Shipping the c/o's wouldn't be all that much...That's one hell of an offer! Shipping could make it costly. -
Yes Jesse everything is original!
Agreed Thorton even though I could afford it.
Jesse, Thank you very much for the offer, however, unless you are coming up my way I have no way to box them up and get them shipped, nor do I have the skills to do the job myself. And if I did, at 22 years old I'd be worried sick about them surviving the trips back and forth I've seen some terrifying photos on here from shipping speakers:eek:! But I do appreciate the offer. Thank you.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
You should take him up on this, it is a win/win for you as you will love it.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Not the speakers, just the crossovers.Political Correctness'.........defined
President of Club Polk -
I am up for taking that offer as well Jesse...:cheesygrin:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Ya know the saying "ignorance is bliss"? I'm sure if I tried out a Emotiva amp I may just be happy since I don't have prior experience with anything else so my ears wont know. haha.
You are the targeted customer.Political Correctness'.........defined
kuntasensei wrote: »I don't doubt you... but what would the advantage be if I'm already not stressing that circuit? My AV gear is the only thing on that circuit as it is, so it is essentially "dedicated". Just curious what a 20 amp circuit would do when I'm not peaking above 11.5 amps at ridiculous levels.
Is it truly dedicated, no other unused outlets on the circuit?
Anyway, a 15 amp circuit will use 14/2 wire, while a 20 amp has to use at least 12/2 or even better 10/2. So, not only are you removing any possible noise issues, you are increasing the wire gauge. Think of it as a garden hose. The larger the hose diameter, the more water will flow. Bottom line, your amps will run cooler and the sound becomes more refined.Political Correctness'.........defined
I'm not going to switch something out just because someone else says that it should be done, especially since I don't have any problems with it. It's called thinking for myself and doing my own thing.
Please forgive me for saying. But that seems somewhat close minded to me. I'm all for doing your own thing....but testing the waters is not a bad thing! With improvements in technology these days. Do you really find it that impossible there are no improvements or upgrades to such an old design? Reminds me of that BASF commercial..."we don't make the things you use, we make the things you use better". :cheesygrin: There are better components built these days.--Gary--
I got a response from KeithL at emotiva's forums..
There was a famous speaker designer (sorry, I forget his name) that once made a speaker that was absolutely ruler flat. When asked how it sounded he said like crap. 'Nuff said.Political Correctness'.........defined
Here we go..^^^^:rolleyes:ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
...Do you really find it that impossible there are no improvements or upgrades to such an old design? Reminds me of that BASF commercial..."we don't make the things you use, we make the things you use better". :cheesygrin: There are better components built these days.
This is the attitude of a tweaker, I am not one. I know that there have probably been tons of improvements made to components. But I have no interest in pulling anything apart to put something new in to see if it makes it better. I'd much rather spend my time enjoying what I have. I have no interest in continually jumping down an endless rabbit hole in search of something better.
For those of you who like to do this, that's great, go for it. I'm not.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Would running mono amps for the front/center be a good return on the sound investment or a waste?Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Just because they're monoblocks doesn't mean they'll sound any better than a 2 or 5 channel amp.
No difference? Then why do they make mono block amps?Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Ok, so the targeted customer is one that wants to power a single speaker then? Sounds stupid..Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Wouldn't the only difference be that there's no chance of crosstalk between the amp channels? I thought that was the point of monoblocks.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
No difference? Then why do they make mono block amps?Ok, so the targeted customer is one that wants to power a single speaker then? Sounds stupid..
In your price range there's not a mono block that could set itself a part from a good 2 or 5 channel amp in that same price point. For $1000 I'd look at a nice 5 channel amp and be done. There's many advantages to monoblocks but your budget won't allow for a good set.
Parasound 2205at or 1205a
Rotel 1095 or 1075
B&k 200.5
Emotiva XPA-5 -
I was looking at getting 3 of these for like $1000 or under as they have specials for multiples.
http://www.outlawaudio.com/products/2200.html
Though after reading some reviews on them I've heard some say its not good for music only for movies.
Then I was also looking at the mono blocks at Emo.. your guys favorite amp manufacture! haha
Cost more but theres a few different models in different price ranges.
Since i'll be waiting a month or so to buy something I figured i'll have a bigger budget.
Just asking if there was something special about using mono blocks instead as its something I could buy a couple now and more later.. just wondering if I was wasting my time thinking about that option.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Point taken. But I still say it's hard to discount so many that like and prefer this tweak. Perhaps it is a guy thing. lol--Gary--
Cfrizz, you are consistent in your logic and posting which is a nice quality to have. If you enjoy your system and like the sound, then sit back, enjoy and crank it up!_____________________________________________________________________________________________
DAC: Bricasti M1SE
LOL it is most definitely a guy thing!
Crankin even as I type Thorton, thanks.
Like everything else in this hobby, it's all a matter of opinion. I would get a 5-7 channel amp and be done. But if you have the outlets to handle multiple amps go for it. You have to start somewhere Eclypse, and if new with warranty and not spending a ton is important to you then get the Emotiva, and get an XPA to make sure you have plenty of headroom. If you are willing to get used gear check out Audiogon for a good deal on a used amp. It all depends on how fanatical you want to get.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Keep an eye on the Club Polk flea market , there's always some used Emotiva amps popping up for sale there. Enjoy the journey!
Hey there, Chris. You still got snow on the ground, ours is all gone.:razz:
I can attest to the used amp thing as my Parasound HCA 2200 came from Chris in the land of the cows and it powers my LSI 9's quite nicely...nice and tight with mellow tone. I have picked up some MIT Shotgun S3's for speaker cables and Shotgun S2 interconnects and when I get the living room back together (paint job) I will have an even nicer system.
On Emo and HT my XPA-5 worked flawlessly however I changed it out for a Parasound 5250 for more power and warmer sound. So far it's Proven to be a wise up-grade. I listen to music about 60% of the time on my big HT rig and while I had my SDA's in the system it was truly a wonderful sound. I have since moved in my RTI-A9's as fronts and for HT they are great but I miss my SDA's for music. I really like the petite graceful look of the RTI-A series over the large box style of the SDA's. I need a new place for my SDA's and I'm running out of room.
To sum it up...amps are a little like women in that they all sound a little different and some are better suited for some activities than others. Try some out, be picky, find one just right for you and stick with it/her.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
michael1947 wrote: »Hey there, Chris. You still got snow on the ground, ours is all gone.:razz:
You are right about that. Some are also drop dead sexy AND do everything they're told with ease and grace, and then come back asking for more.!:cheesygrin:
