Recommended 7 channel x200w Amp
sarvic
Just wondering what people recommend for a good 7-channel amp these days.
Will be used to power:
Fronts: LSiM 703 bookshelf
Center: LSiM 706c
Side Surrounds: LSiM 702 F/X
Back Surrounds: LSiM 702 F/X
thanks!
Center: LSiM 706c
thanks!
Post edited by sarvic on
Someone's gonna ask it, so I'll get it out of the way: What's your budget?Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
no real set budget, just want to see what good quality amps were out there. I guess anything in the $2000-$3000 range.
oh, and that's 200w x 7 in 8ohms -
Krell showcase
polkfarmboy wrote: »Krell showcase
unfortunately that one's only 125w x 7 with 8 ohms -
This was one I was looking at:
http://www.outlawaudio.com/products/7700.html
as well as this one:
http://www.sunfire.com/productdetail.asp?id=4 -
You want something super high end used for that kinda money your talking
Coming soon from Emotiva! :cheesygrin:
350wpc x 7!! Probably within your budget as well, but you'll have to wait for release. Note the power requirements however. :eek:AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it -
this was another possibility:
http://us.marantz.com/us/products/pages/ProductDetails.aspx?CatId=AVSeparates&ProductId=MM8077 -
nice! I was originally looking at the Emotiva's but their current multi-channel one unfortunately didn't have enough power for what I was looking for. -
I've had a NAD M25 for the last year and really enjoyed it. 160W x 7 @ 8 Ohms (220W dynamic). They run about $3500 new, but I've seen them used for ~$2500.
http://nadelectronics.com/products/masters-series/M25-7-Channel-AmplifierDali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
I was gonna say... the closest thing I could think of new was the Nad M25, but that's only 160w/ch and it's $3,500. There's a Lexicon LX7 on Ebay right now for $1,850 and that would work for you. There's also a B&K 200.7 on Audiogon for around the same price. I'd poke around used and see what you can find.Equipment list:
Emotiva XPA-3 amp
Here is my question: Why do you need an amp for those speakers?
Honestly just pick up a Pioneer SC-68 and call it a day. You dont need nearly the wattage you think you do for the LSiM's to drive them to ear bleeding levels. Also factor in you need to double the wattage per 3db you add. So for example if your AVR puts out say 125 x 7 (actual wattage rather than spec wattage) and gives you 100 db, to get to 103 db you need to have 250 x 7 (actual wattage), to get to 106db you need to have 500 x 7 (actual wattage, and more than your speakers can take per spec's). Its hard to tell the difference between db's the higher up you go as well, so you might not even be able to tell the difference sound wise, even though you may pay 2 or 3x more for an amp with those specs.
If you just had to have an amp get a 2 channel one for your front 2, and drive the rest with a really good AVR (again with the Pioneer SC series).
One of the nice things about the redesign of the LSi series into the LSiM series is the move from 4 ohm speakers to 8 ohm ones. Allows you to use an AVR to power them (assuming its a good quality one).
I wouldnt go out and buy a cheapy AVR by any means, but anything in the 1.5k range up should work fine, and then you save yourself the cost of the AVR + an amp + interconnects. Allows for a simpler hookup and cleaner source to speaker connection."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
7ch amps with 200wpc are not very common. You could look into some Parasounds as well. Get a 2ch for the L and R and a 5 channel for the rest. All above 200w with either the new classic or Halo line. Being that you have LSiM's I'd say Halos perhaps.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
They're supposed to have a XPA-7 coming out in the near future that will be 200w/ch x7. At least there's mention in their forums of one. If you're not in a rush and insist on new, that might be worth checking out.nice! I was originally looking at the Emotiva's but their current multi-channel one unfortunately didn't have enough power for what I was looking for.Equipment list:
Emotiva XPA-3 amp
EndersShadow wrote: »Here is my question: Why do you need an amp for those speakers?
I probably won't be getting a receiver yet for my theater room til next year sometime. If I had to get one now, it would be probably the Denon AVR-4520 although I did look at that Pioneer SC-68. The Marantz AV8801 looked nice but i'd need an amp for that one.
Just looking into my options is all.
7ch amps with 200wpc are not very common. You could look into some Parasounds as well. Get a 2ch for the L and R and a 5 channel for the rest. All above 200w with either the new classic or Halo line. Being that you have LSiM's I'd say Halos perhaps.kuntasensei wrote: »They're supposed to have a XPA-7 coming out in the near future that will be 200w/ch x7. At least there's mention in their forums of one. If you're not in a rush and insist on new, that might be worth checking out.
Again fella's I askEndersShadow wrote: »Here is my question: Why do you need an amp for those speakers?
Surrounds will never need that much power, and lets remember the LSiM's are 8 ohm speakers so they are not the LSi's of past which required an amp to sound good.
The LSiM's should sound quite good on a high end AVR that has close to its rated spec's per channel with all channels driven. I dont think the OP needs an amp for all 5 speakers by any means, maybe the front 2, but with his budget he could just get the Pio 68 and call it. He wont get more out of the LSiM's without REALLY upping his budget and I dont think there would be enough of a difference to justify the cost.
Keep in mind every 3 db increase in SPL requires double the wattage.
Also we dont know room size, are we talking a 10x12 room, a 300x500 room, etc as that plays into all this.
Lets not get too far down the amp rabbit hole before ensuring its one we actually need to go down."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Do you have the speakers now? If so how are you driving them?
The Marantz SR7007 would be what you would need, you dont have to go separates with the LSiM's and honestly think you would spend more cash than you needed doing so."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Again fella's I ask
I'll concede here. Good stuff to think about. Just figured if he was asking about amps he had searched receiver options.AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
Well, right now I just temporarily have them hooked up to my Denon AVR 2309 receiver in my living room.
As far at the dimensions of the theater room, they are 15x21 with about an 8-9' ceiling.
Was looking to purchase the speakers first, then various electronics and media furniture next, then lastly the TV and receiver to take advantage of the latest tech...
Yes, I have the speakers right now minus the dual subs which I was gonna get the SVS PB-12's -
The dimensions of my HT are very close to yours (13x19x7) and I'm running all Rti-A series speakers in a 7.2 system. My fronts are powered off a 5ch Sony ES amp (120x5) that is bridged to 200x200 with the fifth channel at 120w for the center.
With room treatments, and my Onkyo 1010 running the side and back surrounds nothing breaks a sweat even near reference volumes. I'm sure I could run just the Onkyo for everything and be fine. Guess what I'm trying to say is a dedicated amp for everything is not necessary. If you really want an amp, save some coin and just get a 2 or 3 channel amp as others have said. Let your AVR do the rest. If I had bought an Onkyo 3010 or 5010 I wouldn't even keep the dedicated amp in the mix.
Also make sure you have the space for the PB-12's. I considered those, but they were just too big. So I got the PC-12's instead.
Not sure this really adds anything to the conversation.. too much coffee today.... -
Well, thanks to everyone's input here, I reckon i'll just stick with a nice receiver instead of getting a separate amp. Hope to see some potential new things coming out for CEDIA 2013 this year. Thanks again for the help with this.
Wyred4sound. Nuff said.
Yeah, I saw that one. Definitely a nice price.
I would only get a receiver with Audyssey XT32 or the equivalent (Anthem's ARC is the only thing that comes to mind) unless you are EQing your subs separately. Good speakers (which you have), dual subs, and room correction/treatments are the biggest improvements. -
Just curious since it pertains to the conversation, how does that Pioneer receiver put out 140wpc all channels driven and only weighs 40lbs?? What kind of tech allows for this?AVR - Onkyo NR809
Center - CSi5
Surround - FXiA6's
Sub - psw505
TV - Toshiba 52" HD
ICE Amps which are Class D. But dont ask me what that means lol..."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yup. Same reason my Crown XLS-1500 weighs all of 8 pounds and yet puts out 525w/ch at 4 ohms. It replaced a Samson 1000 that weighed 4x as much and yet it controls my sub and Buttkicker MUCH better. It's scary how light Class D amps are.EndersShadow wrote: »ICE Amps which are Class D. But dont ask me what that means lol...Equipment list:
Emotiva XPA-3 amp
Sunfire 72012-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Class D amps as Enders mentioned. I think in testing, the SC 57 receiver put out ~110+ wpc 7 channels driven, which seems pretty decent.
http://www.hometheater.com/content/pioneer-elite-sc-57-av-receiver-ht-labs-measuresDali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
