Help with speakers for new HT setup
Yup get the A6 to match the A5 since they have the same large 6 1/2" woofers. The center channel is the most important since that one will do most of the work for movies and dialog.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
If your looking for decent sounding speakers for the budget minded, I would look at Energy speakers. Best buy sells them, and they don't sound half bad. Not a big fan of Primus myself, just don't particularly care for the sound, but again that's just me. I would suggest that you take a day, go to a couple/few stores, and demo speakers. You have a good AVR, just get some really big bookies for the fronts, or a floor stander. You have a fairly large room, and even though small satelite type speakers may fit the decor better, you probably won't be impressed with the sound.
Options on craigslist:
Polk RT8 fronts w/ RT5 surrounds for just under $200:
http://philadelphia.craigslist.org/ele/3695344663.html
http://philadelphia.craigslist.org/ele/3674154339.html
Not familiar with these, but worth mentioning in Williamstown:
http://southjersey.craigslist.org/ele/3622220724.html
Some other Mirages in your area
http://philadelphia.craigslist.org/ele/3724443370.html
http://philadelphia.craigslist.org/ele/3742804306.html
You could consider Def Tech:
http://philadelphia.craigslist.org/ele/3678239417.html
http://philadelphia.craigslist.org/ele/3755240514.html
http://philadelphia.craigslist.org/ele/3621349849.html
Might have to drive a bit for these, but if B&W is your cup of tea:
http://newjersey.craigslist.org/ele/3735556603.html
Thanks for searching an posting those links.
Now I am also considering the Focal Chorus 706v bookshelves or the 814v floor standing speakers.
I will try to locate a dealer so I can listen to them.
Anyone care to comment on the Focals.
