Speaker Stands for Polk LSiM 703's
Thanks, appreciate that!
Any good cheap places online to get the shot or should I just get it from a local sports store?
Whether you can find it cheap online or not, shipping would grab you by the 'nads! :razz:
Best to just pick it up locally. -
Local sounds best unless some place gives you free shipping cause it would weight a lot!Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
anyone use kitty litter to fill their stands?
my 2 cents worth, they are not height adjustable speaker angle only
http://www.ceshowroom.com/Atlantic-77335799-Bookshelf-Speaker-Stand_p_41904.html
http://www.amazon.com/Atlantic-77335799-Adjustable-Bookshelf-Speaker/dp/B007P8DKDE/ref=pd_cp_e_2POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Yes, and I find that used kitty litter gives most speakers a more coherent soundstage than fresh.
Why not just fill them with molten iron like a real man?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Someone mentioned this in a forum as a possible filler:
http://www.divineaudio.co.uk/atacama-atabites-smd-z7-5hd -
That would work, but lead shot is still the best. Besides, shipping that from the UK is going to be very expensive.Political Correctness'.........defined
President of Club Polk -
I'll second the lead shot - no mess, extremely effective, very dense. i.e. perfect for stands.11.3 Theater
RTi A7 Fronts - CSi A6 Center - 65-RT DSX Wides - RTi A1 DSX Highs - FXi A6 Rears - FXi A6 Surround Backs
eD A5-350 (L-LFE) - eD A5-350 (R-LFE) - SVS 20-39+ (Rear-LFE) - Aura Pro x 8 Seats
Onkyo TX-NR3010 (11.3 Neo:X) - Sony TA-N9000ES Amplifier
JVC RS-20u - Elite 120" 1.3 Gain - XBMC Processor - TrippLite 30A Full Theater Backup
2.1 Studio / PC
Mackie HR824 Powered Monitors - Infinity Kappa Perfect 12" DIY
Aune USB 24/192 DAC HPA - Sennheiser HD650/600
