Speaker Stands for Polk LSiM 703's
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2013
    Thanks, appreciate that!
  • sarvic
    sarvic Posts: 51
    edited April 2013
    Any good cheap places online to get the shot or should I just get it from a local sports store?
  • teekay0007
    teekay0007 Posts: 2,288
    edited April 2013
    Whether you can find it cheap online or not, shipping would grab you by the 'nads! :razz:
    Best to just pick it up locally.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Local sounds best unless some place gives you free shipping cause it would weight a lot!
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • sarvic
    sarvic Posts: 51
    edited April 2013
    anyone use kitty litter to fill their stands?
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2013
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2013
    sarvic wrote: »
    Yes, and I find that used kitty litter gives most speakers a more coherent soundstage than fresh.
    Why not just fill them with molten iron like a real man?
  • PolkieMan
    edited April 2013
    play sand is cheap less dust?
    sarvic wrote: »
  • sarvic
    sarvic Posts: 51
    edited April 2013
    Someone mentioned this in a forum as a possible filler:
    http://www.divineaudio.co.uk/atacama-atabites-smd-z7-5hd
    F1nut Posts: 52,371
    edited April 2013
    sarvic wrote: »
    That would work, but lead shot is still the best. Besides, shipping that from the UK is going to be very expensive.
  • theta
    theta Posts: 51
    edited April 2013
    I'll second the lead shot - no mess, extremely effective, very dense. i.e. perfect for stands.
    11.3 Theater
    RTi A7 Fronts - CSi A6 Center - 65-RT DSX Wides - RTi A1 DSX Highs - FXi A6 Rears - FXi A6 Surround Backs
    eD A5-350 (L-LFE) - eD A5-350 (R-LFE) - SVS 20-39+ (Rear-LFE) - Aura Pro x 8 Seats
    Onkyo TX-NR3010 (11.3 Neo:X) - Sony TA-N9000ES Amplifier
    JVC RS-20u - Elite 120" 1.3 Gain - XBMC Processor - TrippLite 30A Full Theater Backup
    2.1 Studio / PC
    Mackie HR824 Powered Monitors - Infinity Kappa Perfect 12" DIY
    Aune USB 24/192 DAC HPA - Sennheiser HD650/600
