Best bang for the buck sub cable?
SniperREX
I'm using a Monster MB300 right now, is it good? I still have about 10 days to return it.
Any advice for sub cables under $80?
I'm a newbie in the sub sector. My PSW303 is the first real sub that I have ever owned.
Should I use a Y adaptor instead of a LFE cable?
TVs: Samsung S95B 65" QD-OLED (den) and LG C2 42" OLED (office)
Receiver: Denon AVR-X3700H (den) and Denon AVR-X2300W (den)
SACD and DVD-A player: Oppo BDP-83
Mains: Polk RTi8 (den) and Dali Ikon 8 (office)
Center: Polk CSi5 (den) and Polk CSi3 (office)
Surrounds: Polk FXi5 (den) and Velodyne surrounds (office)
Sub: SVS PB-2000 (den) and PCi 16-46 (office)
Post edited by SniperREX on
www.signalcable.com
Tell Frank you are a Club Polk member, and get a small discount.
Welcome to the board, nice to see another Texan here. Stay tuned for the Texas Polk Gathering III, you won't want to miss it.
Cheers,
Personally, I've found cables from bettercables.com to be excellent. The Silver Serpent cables are especially good, and their Subwoofer Silver Serpent starts at $45, but you'll probably need to spend a bit more if you need a longer length. I'm sure if you spend the dough to get a reference cable like Signal or Bettercables, that they will all sound just as good, so pick the cheapest or who you're more comfortable dealing with.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
The MB300 should be just fine for the 303. Save your $.
Regards,
PolkThug -
i concur with polkthug
See above 2 comments. What you have is more than adequate.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'll upgrade to the PSW505 this weekend.
Will the MB300 still be adequate?
Sub: SVS PB-2000 (den) and PCi 16-46 (office) -
Yep, coax works great.
I would personally recomend just taking one step up to the MB400. First of all you get a slightly heavier cable. But even better you get the twist lock ends (better connection) plus a matching Y adapter so that you can experiment and see which you way you prefer it. I think It's worth the extra 5 to 10 bucks, especially when you consider the Y by itself is $15.
Also now that you are getting the 505 I think you might actually be able to hear the difference.
Enjoy your new toy!!
DaveHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
