Best bang for the buck sub cable?
SniperREX
SniperREX Posts: 930
I'm using a Monster MB300 right now, is it good? I still have about 10 days to return it.
Any advice for sub cables under $80?
I'm a newbie in the sub sector. My PSW303 is the first real sub that I have ever owned.
Should I use a Y adaptor instead of a LFE cable?
TVs: Samsung S95B 65" QD-OLED (den) and LG C2 42" OLED (office)
Receiver: Denon AVR-X3700H (den) and Denon AVR-X2300W (den)
SACD and DVD-A player: Oppo BDP-83
Mains: Polk RTi8 (den) and Dali Ikon 8 (office)
Center: Polk CSi5 (den) and Polk CSi3 (office)
Surrounds: Polk FXi5 (den) and Velodyne surrounds (office)
Sub: SVS PB-2000 (den) and PCi 16-46 (office)
Post edited by SniperREX on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2004
    www.signalcable.com
    Tell Frank you are a Club Polk member, and get a small discount.
    Welcome to the board, nice to see another Texan here. Stay tuned for the Texas Polk Gathering III, you won't want to miss it.
    Cheers,
    Russ
  • gregure
    gregure Posts: 871
    edited June 2004
    Personally, I've found cables from bettercables.com to be excellent. The Silver Serpent cables are especially good, and their Subwoofer Silver Serpent starts at $45, but you'll probably need to spend a bit more if you need a longer length. I'm sure if you spend the dough to get a reference cable like Signal or Bettercables, that they will all sound just as good, so pick the cheapest or who you're more comfortable dealing with.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2004
    The MB300 should be just fine for the 303. Save your $.
    Regards,
    PolkThug
  • jefft1314
    jefft1314 Posts: 169
    edited June 2004
    i concur with polkthug
  • steveinaz
    steveinaz Posts: 19,538
    edited June 2004
    See above 2 comments. What you have is more than adequate.
  • SniperREX
    edited June 2004
    I'll upgrade to the PSW505 this weekend.
    Will the MB300 still be adequate?
  • wallstreet
    wallstreet Posts: 1,405
    edited June 2004
    Yep, coax works great.
  • cmy330go
    cmy330go Posts: 2,341
    edited June 2004
    I would personally recomend just taking one step up to the MB400. First of all you get a slightly heavier cable. But even better you get the twist lock ends (better connection) plus a matching Y adapter so that you can experiment and see which you way you prefer it. I think It's worth the extra 5 to 10 bucks, especially when you consider the Y by itself is $15.
    Also now that you are getting the 505 I think you might actually be able to hear the difference.
    Enjoy your new toy!!
    Dave
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
