Does anyone know about the connection type please??????
Hi all, please can somebody tell me what type of connection is on the atrium outdoor speakers (6 if specific) I'm looking at using 16 gauge oxygen free cable (I hope that's correct)???
And wasn't sure if I need to buy additional connectors ( banana plugs) to connect them????? I'm just trying to get it all sorted before the speakers come. Any advice is really really appreciated
God bless:cheesygrin:
They will accept bare wire, spades or banana plugs.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
Thanks so much, I'll crack on and get either spades or bananas. Thanks.
No problem. Nakamichi plugs are awesome btw. Just bought a pack of these and they work great: http://www.nakamichiplug.com/product-0857F12.htmlDisplay: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Thanks, will do, just reading up on banana plugs being that they seem a lil easier to connectetc, do you know if the polka accept a dual plug???? As reading a lil about it, the spacing needs to be the same???? Ill check out the nakamichi plugs now.
Just checked out themnakamichis I'm over in the u.k, I can get the on ebay for about £4.75 Gbp for 4...so I'm gonna order some if that's what you recommend..........
Not sure if dual plugs will work. I've had issues with them in the past with them not fitting. The ones you're looking at on Ebay should work just fine, though.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
I was unable to use banana's due to the lack of clearance when hanging with their bracket, ymmvSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Ohhhh.....that's interesting, what did you use yourself??? Spades???
