Does anyone know about the connection type please??????
Hackers24
Hackers24 Posts: 17
edited April 2013 in Speakers
Hi all, please can somebody tell me what type of connection is on the atrium outdoor speakers (6 if specific) I'm looking at using 16 gauge oxygen free cable (I hope that's correct)???
And wasn't sure if I need to buy additional connectors ( banana plugs) to connect them????? I'm just trying to get it all sorted before the speakers come. Any advice is really really appreciated
God bless:cheesygrin:
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2013
    They will accept bare wire, spades or banana plugs.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Hackers24
    Hackers24 Posts: 17
    edited April 2013
    Thanks so much, I'll crack on and get either spades or bananas. Thanks.
  • HTguru1982
    edited April 2013
    No problem. Nakamichi plugs are awesome btw. Just bought a pack of these and they work great: http://www.nakamichiplug.com/product-0857F12.html
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • Hackers24
    Hackers24 Posts: 17
    edited April 2013
    Thanks, will do, just reading up on banana plugs being that they seem a lil easier to connectetc, do you know if the polka accept a dual plug???? As reading a lil about it, the spacing needs to be the same???? Ill check out the nakamichi plugs now.
  • Hackers24
    Hackers24 Posts: 17
    edited April 2013
    Just checked out themnakamichis I'm over in the u.k, I can get the on ebay for about £4.75 Gbp for 4...so I'm gonna order some if that's what you recommend..........
  • HTguru1982
    edited April 2013
    Not sure if dual plugs will work. I've had issues with them in the past with them not fitting. The ones you're looking at on Ebay should work just fine, though.
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • sandworms
    sandworms Posts: 1,043
    edited April 2013
    I was unable to use banana's due to the lack of clearance when hanging with their bracket, ymmv
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Hackers24
    Hackers24 Posts: 17
    edited April 2013
    sandworms wrote: »
    Ohhhh.....that's interesting, what did you use yourself??? Spades???
