Building My Own Box
aort237
aort237 Posts: 6
edited June 2004 in Custom Fabrication
doeas anybody have a good blueprint or guide for building a sealed box made of 3/4 mdf for two 12's
Adam
Post edited by aort237 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2004
    i bet polk does... put two of these together. or not. if you need a more-specific design, ask away.
  • grodgers
    grodgers Posts: 1
    edited June 2004
    for 2 12" whats?
    IOW box size should be made to accommodate the T/S parameters of the sub(s) you're putting in it.
    There is no "one size fits all" - now, yes there are pre-made boxes - and you can most likely find a "close enough" sealed box for your subs... But if you're making a box, why not make it exactly the right size?
  • neomagus00
    edited June 2004
    ah, excellent point... i assumed he had 2 polk 12s...
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2004
    im also looking to build my own box for 1 12. any blue prints and directions for someone who doesnt know how to build stuff? like me
  • neomagus00
    edited June 2004
    which 12?
  • Airplay355
    edited June 2004
    stryke av 12 mkii
  • exalted512
    exalted512 Posts: 10,735
    edited June 2004
    youre going to have to provide a little more info than that...do you want it sealed or ported?
    whats the recommended size for each?
    what are the t/s parameters?
    do you have any size restrictions?
    -Cody
  • Airplay355
    edited June 2004
    exalted....see my other post about the $400 sub for details
