Building My Own Box
aort237
doeas anybody have a good blueprint or guide for building a sealed box made of 3/4 mdf for two 12's
Adam
Post edited by aort237 on
i bet polk does... put two of these together. or not. if you need a more-specific design, ask away.It's not good, very fundamentally simply not good. - geolemon
for 2 12" whats?
IOW box size should be made to accommodate the T/S parameters of the sub(s) you're putting in it.
There is no "one size fits all" - now, yes there are pre-made boxes - and you can most likely find a "close enough" sealed box for your subs... But if you're making a box, why not make it exactly the right size? -
ah, excellent point... i assumed he had 2 polk 12s...It's not good, very fundamentally simply not good. - geolemon
im also looking to build my own box for 1 12. any blue prints and directions for someone who doesnt know how to build stuff? like me
which 12?It's not good, very fundamentally simply not good. - geolemon
stryke av 12 mkii
youre going to have to provide a little more info than that...do you want it sealed or ported?
whats the recommended size for each?
what are the t/s parameters?
do you have any size restrictions?
exalted....see my other post about the $400 sub for details
