bridging NAD amplifiers
    heiney9 Posts: 25,445
    edited April 2013
  • organ
    organ Posts: 4,969
    edited April 2013
    Dual mono is completely different than bridging two stereo amps.
    edited April 2013
    organ wrote: »
    Yep, it sure is.
  • ALL212
    ALL212 Posts: 1,658
    edited April 2013
    I just can't help it - might be genetic...
    Once bridged aren't the "stereo" amps mono?
    From the manual:
    "This switch "bridges" the two power amplifier channels to form a monophonic amplifier"
    You can only drive the left channel with the 7400 at that time and must use another amp- hopefully the 2400 - to drive the right channel. You then use the Pre-out of the 7400 right channel to supply signal to the 2400. The only change up here is that the 7400 supplies the left channel, sans cable, to the power amplifier section of the integrated amp.
    I'm not sure how dual mono is completely different? My dual mono amp has separate power, boards, caps and transformer. One for each channel. It's just a space saver, I don't need two chassis'. Just to be clear I'm not bi-amping. In the classic dual mono situation (assuming I had two fully separate physical amps) I would use one amp (in this case the bridged 7400) for the left channel and left only. I would use the other amp (in this case the bridged 2400) for the right channel and right only. No more stereo from either amp. One speaker wire comes from the 7400, the other from the 2400.
    I understand they weren't born as mono amps but they certainly had the surgery to become mono amps.
    Aaron
    Enabler Extraordinaire
  • FTGV
    FTGV Posts: 3,650
    edited April 2013
    Qualitive questions aside by definition those amps bridged would become mono blocs.
  • ALL212
    ALL212 Posts: 1,658
    edited April 2013
    That is true, however my point is that there is no longer a stereo amp after bridging. Whether housed in a single chassis or multiple they are mono. Therefore they are not "completely different" - see post #35 and #36.
    Because of that...blah blah blah reference post #33.
    Aaron
  • FTGV
    FTGV Posts: 3,650
    edited April 2013
    ZLTFUL wrote: »
    It's semantics
    Certainly
    . Monoblock by its very definition is a single channel amplifier in a single chassis.
    True which is really what you end up with when bridging a pair of like amplifiers since the two ch. within each now function as one.
    F1nut Posts: 51,787
    edited April 2013
    There are notable differences between bridged amps and a purpose built dual mono amp or mono blocks. Two examples off the top of my head are that a dual mono amp or mono blocks have lower distortion and the ability to drive low ohm loads.
  • FTGV
    FTGV Posts: 3,650
    edited April 2013
    Absolutely. Many of the higher powered monoblocks(ie.Pass,Bryston)actually use balanced /bridged output stages but the two halves of the circuit have been closely gain matched so that common mode distortion is cancelled or reduced.Everything has been optimised for mono operation.While I have seen test results on well designed stereo amps that actually have lower THD when bridged it certainly won't be the case with ones that have poor matching between it's two channels.
  • organ
    organ Posts: 4,969
    edited April 2013
    ALL212 wrote: »
    If you're looking at it as a stereo amp becoming a mono amp, yes, it's the same as a mono block because the stereo amp just turned to a mono amp when bridged.
    However, the circuitry and result will be completely different.
    Say we buy two different amps from the same manufacturer. One is a stereo amp in a single chassis. The other is the exact same amp built into seperate chassis (mono blocks). Both output 120w/ch.
    Get another one of the stereo amp and bridge them for 240w/ch.
    Driving the same speakers, the 240w bridged amps won't be able to handle low impedance like the 120w mono block. When you bridge a stereo amp, it will cut your speaker impedance by half and increase THD.
  • 1ShotBill
    1ShotBill Posts: 30
    edited April 2013
    So I bought the NAD 7020 integrated amp and am currently using it as a preamp in conjunction with the NAD 2400THX power amp. There is more than enough power to drive my Polk Audio RTA 12C speakers! Very rarely do have the volume knob up past 1/4. Any higher and the neighbors might have the cops at my front door. I'm very happy with the quality of the sound. Thanks again to everyone in this forum!
  • 1ShotBill
    1ShotBill Posts: 30
    edited April 2013
    Not sure why my photo was inverted while uploading from my iPhone. Lets try that again...
  • plainoledave
    plainoledave Posts: 408
    edited April 2013
    The 7400 has the same specs as the 2400. Ditch the 2400 amp. If you need more "safe" power, get a NAD 7600 (150x2, 500 wpc tone burst). There is a *huge* difference between the 7400 and 7600 when i tested them on my rti10's.
    Sorry, just saw your post stating you got the 7020. Do you hear a difference between the 7020+2400 as opposed to using the 7400 alone?
  • 1ShotBill
    1ShotBill Posts: 30
    edited April 2013
    I started this thread because I was considering purchasing a NAD 7400. However, after all of the feedback I decided against buying one. So I'm afraid I can't tell you if that would sound much different than my current setup.
  • 1ShotBill
    1ShotBill Posts: 30
    edited January 2014
    Update: I've replaced our NAD 2400THX power amp with a NAD 2600 power amp, which has had speaker relays and caps replaced. I'm quite happy with the sound quality it provides in tandem with our NAD 1300 pre amp. The 2400 will be our backup amp.
