KEF 107's
A buddy of mine just picked up a pair of KEF 107's and he told me one of the tweeters is not working properly. I have not heard them yet but suggested he switch the tweeters around and see if the problem follows the tweeter.
We'll see what happens next
Any of you guys familiar with these speakers? Jeff said something that kind of concerned me...... he has the Denon receiver the guy used with the KEF's. I told him not to use it but to use his old Sansui AU-?? integrated amp instead.
If the problem is in the x-over where should he go for a fix? He told me they are from the mid-80's and if that's true maybe the caps have started to go bad :redface: They also have a broken binding post.
Any suggestions are always appreciated.
Welcome to my world :cheesygrin: -
I just did what you told him to do to my speakers..switched tweets over--it was the xover gone bad on my ksf's..i ended up ordering some off ebay for 50.00 to my doorstep. Easy fix. And now the tweets work perfect--have you researched that model to see if others have had issues like that/google----mine i think were damaged in transport or just one of those things that happen
good luck. Keep us updated with outcome. RandyRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Have him check all wires. I had to open mine right up. I also bipassed wire with other wires to see if it was a wire issue--nope. Xovers gone--i contacted company with NO LUCK--thatll teach me for not buying all polk speakers...lol. Good luckRandy-Maine
by David WMG
