usb dac and hub
canadianicon25
canadianicon25 Posts: 200
edited April 2013 in Electronics
has anyone had success using an external USB DAC with a USB hub? if yes, what kind of hub did you use?
Post edited by canadianicon25 on
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2013
    I can't answer that, but are you asking if a PC and DAC are both plugged into the hub will it work?
  • canadianicon25
    edited April 2013
    i am talking about having a USB hub connected to a laptop. Plugged into the hub is the external DAC and other devices. The hub I currently have it causes popping noises to appear in the audio. I was wondering if there is a USB hub out there that is perhaps better quality than the one I have (which is a very generic, low price model).
