Adcom 5802 and Polk lsi25
Sidpaulino
Hi ! I am using an Adcom 5802 to power my Polk lsi25 ! The speakers are about 40 feet from the amp , I am using 10 gauge monster speaker cable! My concern is that my amp runs super hot with louder volume ! ( I like loud music, that's the reason for the system) I am getting the thermal light warning !!
Any suggestions to cool the amp?
Post edited by Sidpaulino on
Turn the volume down...
I have the same amp and have never had the light come on.. Maybe take it in and have it serviced.. -
Do you think using a fan will help?
What speaker you have? -
I wouldn't do it without it being checked out..
SDA SRS 1.2tl's -
I run that amp with LSi15s and it gets "warm" never hot. I would have it checked out.
i ran the same Amp with my SDA 2.3TLs and LSi15s with no issues at all. i would have it checked out.mole'
Ok, I live in a small town ! How do I go around finding a good place to take it to?
Have you taken your amp for service? How often that should be done?
