RC85i mounted in ceiling
Nails1
Maybe a dumb question but I'm going to ask anyway: is there any reason to be concerned with the drywall in my ceiling holding the weight of the RC85i speakers?
It is 1/2 inch drywall.
Post edited by Nails1 on
None at all. The speakers have clips that keep the speakers securely in place.
I should have been more clear. I meant the weight of the speakers - will the drywall hold or should I expect it to bow from the weight?
1/2" drywall should be fine.
I just did some in-ceilings in my basement. It was drop tile so I backed the tile with 1/4" mdf board, but I think with drywall you should be fine.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
