RC85i mounted in ceiling
Nails1
Nails1 Posts: 2
Maybe a dumb question but I'm going to ask anyway: is there any reason to be concerned with the drywall in my ceiling holding the weight of the RC85i speakers?
It is 1/2 inch drywall.
  • wallstreet
    wallstreet Posts: 1,405
    edited April 2013
    None at all. The speakers have clips that keep the speakers securely in place.
  • Nails1
    Nails1 Posts: 2
    edited April 2013
    I should have been more clear. I meant the weight of the speakers - will the drywall hold or should I expect it to bow from the weight?
  • hochpt21
    hochpt21 Posts: 5,423
    edited April 2013
    1/2" drywall should be fine.
    I just did some in-ceilings in my basement. It was drop tile so I backed the tile with 1/4" mdf board, but I think with drywall you should be fine.
