Yamaha RV-X1900 vs Pioneer SC-1222
critical_gp
critical_gp Posts: 84
edited April 2013 in Electronics
Hey Guys,
Which one is the better receiver in general?
I will be running Monitor70 2.0 setup.
You input is much appreciated!
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/SC-1222-K
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v1900_black__u/?mode=model
Audio system lost to water damage... :(
Post edited by critical_gp on
  • chumlie
    chumlie Posts: 8,658
    edited April 2013
    Between the two you have listed. I would go with the Yamaha.
  • adb3da
    adb3da Posts: 507
    edited April 2013
    That Pioneer is newer and has more network features like AirPlay, Pandora etc... Pioneer and Yamaha each have their own room correction software (i.e. a non-Audyssey program). I'm not familiar with either but since the Pioneer's is 3-4 years newer it could potentially be more advanced. If it's something you would use you should probably do more research on that. Also, the Yamaha won't support 3D if you're into that.
    If it was my decision I'd go with the Pioneer but the Yamaha is nice too.
  • chumlie
    edited April 2013
    Don't that suck. One for Yamaha, one for Pioneer. I have a Yamaha RX v2400 and a Pioneer Elite vsx-33. For 2 channel system with no external amp. I would still go with the Yamaha.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2013
    Hey Guys,
    Which one can you get for cheaper?:cheesygrin:
    And, have you looked at the features you want now or are considering to make sure both of these are viable selections?
    [fyi - I still have a V1800 for movies and multi-channel music when the mood strikes me - and overall have been pleased with it. I have moved up for 2-ch listening though by using an integrated amp with HT Direct for my SACD & TT connections.]
  • critical_gp
    edited April 2013
    Thanks for the input guys, I will stick with the Yamaha and I'm thinking of picking up a Yamaha A-S500 AMP for stereo mode.
