Older Amps - ON or OFF?
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited March 2013
    gdb wrote: »
    I turn my stuff OFF, if only to avoid the chance of burning my house down. How important is a longer lasting amp........ compared to a building to house it in ? :wink:
    Remember the old phase linear or as they are still known as the " flame" linear.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited March 2013
    I talked about this on the original thread.I always thought you should keep your electronics off w/ the more modern ones
    having a stand /by feature. Now while saying this I looked over at the rear of my Klipsch sub and it's an amplifier and it's
    never been off for years except for the oncoming electrical storm. So hypocrit,I don't know my Adcom does stay off.
  • soundfreak1
    edited March 2013
    I dont think your sub amp is "on" it has a small trickle of voltage awaiting a "signal" from your processor ant than it "wales" up and goes to full power.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited March 2013
    Here's a curveball for the thread, what about leaving everything on, but connected to a power conditioner that you turn on and off, thus turning everything on/off at once?
    For example, I've got everything hooked into a Monster HTS2600II and with pressing the single button on the front of the unit I can turn everything on or off. I leave the Marantz and the Parasound in the on position all the time. Hit a single button, everything powers up. Good? Bad? Doesn't matter?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2013
    A variation on Inspector 24's theme:
    What about leaving the power conditioner (built on a 5kVA toroidal isolation transformer) on all the time, and turning CD player, preamp, and amps on and off?
    I've wondered about what effect being constantly on would have on the toroidal transformer and also the power consumption with no load on the power conditoner.
  • cc43fan
    cc43fan Posts: 22
    edited March 2013
    gdb wrote: »
    Agreed. I turn them off.
  • Glen B
    Glen B Posts: 269
    edited April 2013
    AFAIK, there should be no effect on an isolation transformer being on all the time. I've been running balanced isolation transformers continuously for many years, except for times when there is a thunderstorm, where I unplug everything. The no-load power consumption is extremely small, just a few milliamps.
  • bthogan
    bthogan Posts: 151
    edited April 2013
    1. Leaving my Parasound on doesn't appear to have any effect, positive or negative, on performance, so I turn it off. Seems like a good idea in terms of safety etc.; I haven't really thought about the issue of wear from powering on and off.
    When I get my McCormack DNA-1 back, I'll always leave it on. That's somewhat specific to the gear, though. Like some solid states, it does sound better after it's been on for a bit. I'll probably turn it when I go on vacations.
    2. Linguistic analysis has its limits, but at the same time, that continental stuff can get pretty sophistical; we have to police it somehow. There must be some middle ground between the strictly analytical approach to expression and culture - which tends toward sterility, and an inability to incorporate dimensions of consciousness and human existence that are neglected by the reductive ontology of the "rational animal" - and the worser consequences of post-structuralism, which can tend toward willfully obscure bull****. I've always been struck by the analytical side's neglect of the Heideggerian critique of the strictly analytical approach, as seen in (e.g.) Being and Time - a critique, of course, but not a rejection; something that Derrida et al. seem to have missed. Of course, he was a ****; that might have had something to do with it.
    Hope this helps.
    Marantz CD6004
    Adcom GFP-750
    McCormack DNA-1
    Polk LSi9s
    Signal Cable ICs
    Blue Jeans cables
