New Harman Kardon amp!!!
proffitt
Ok, I just picked up my very first dedicated separate amp. It's certainly not new, just new to me. It's an HK Citation 22. My question is on setup. My speakers are SDA SRS 2. I think I've heard they are rated at 6 ohms? So the amp has a setting to select either 8 ohm or 6 ohm. Which should I use? Also, the amp has a lug for ground. Short of driving a ground rod through my basement floor, what should I connect this to?
Thanks for helping with my elementary questions!
Post edited by proffitt on
Sorry, correction. The amp has setting to select either 8 ohms or 4 ohms. Which should I choose?
4 ohms but you can try both and see which you like the best.
I tried 4 and 8 ohms on my 8 ohm LS90s, 8 ohm sounded much better.Speakers: SDA-1C (most all the goodies)
There will be more power available in the 8 ohm mode but that could result in excessive heat generated in the ouput section if driving lower impedance speakers hard.Switching the selector to 4 ohm mode lowers the main rail voltages so less heat will be generated( safer operating temp range for output transistors)but also results in a reduction in peak power.The amp has setting to select either 8 ohms or 4 ohms. Which should I choose? -
Pics or it didnt happen
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
my bad, another correction. This link:
http://www.polksda.com/sdasrs2.shtml
Says that the speakers are 4 ohm. So I should set the amp selctor from 8 ohm to 4 ohm, correct?
I tried it last night on both settings, and the 8 ohm seemed to offer much more umpf.
I guess I am in danger of damaging equipment in the 8 ohm setting? -
I think you would be fine at 8 Ohms for moderate listening and 4 Ohms for rocking out....IMO.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
I would set it at 4 ohms. You should notice more heat with it set at 8 ohms.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Hope you LOVE your new HK unit. Enjoy and keep us updatedRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
